![]() | Home > In Car Electronics > TD5 Centre Dash Illumination? |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 ![]() ![]() |
Mine all light up apart from 2 x auxilary light switches that don't seem to do anything!
Yes
![]() My build thread http://www.defender2.net/forum/topic17615.html |
hunter_pa Member Since: 15 Aug 2016 Location: Northern Ireland Posts: 18 ![]() ![]() ![]() |
Any idea where I can start to look to diagnose the problem? The illumination works in the main dash (speedometer, fuel, temp and clock dials). All the switches work on the centre console, and the red/orange indicator lights work for the heated seats/heated windscreen etc
It's probably just the bulbs gone. Ray
Oh? It's not individual bulbs/Leds in the acutual switches then?
Didn't get a chance to take the dash apart tonight, too busy fishing another wire for the broken dormer door wire. Took much longer than expected ![]() |
Flip the cap off each switch where the illumination is not working and the bulb is Under the cap. Assuming your defender is a late td5 as per your profile. Ray
It's a 2005
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 108 ![]() ![]() ![]() |
How do you flip the cap off? Alex |
Look like Leds under the cap, the red light works just not the illumination led. Along with every other led in the dash. ![]() Click image to enlarge Know what wires supply what here? ![]() Click image to enlarge |
I think (but may be wrong) that the clear bulb is just a 5w capless bulb so should just pull out with something like needle nose pliers but I'm doubting myself now. Maybe someone else will give a definate answer. Ray
![]() Click image to enlarge Got the switch apart, little LED's soldering directly to the board. Will test car side connection and this tomorrow with my multimeter |
Well, I could have sworn they were capless bulbs
Could it be that a fuse needs to be replaced in the fuse box?
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
Where do you have illumination? Do the gauges and heater control labels illuminate?
Sounds like it could be Fuse 20 (10A) on the bulkhead fuse box - this supplies the illumination for the centre console. The illumination is the red with orange stripe wire throughout the loom. ![]() ![]() |
