Home > In Car Electronics > TD5 Centre Dash Illumination?
hunter_pa
United Kingdom 2005 Defender 110 Td5 XS CSW Bonatti Grey
First post on the forum, ran a little search on here and on Google but couldn't get a definitive answer.
I picked up my first Defender last month, 2005 110. Sorted 1/2 of the problem where the interior lights not switching on when the doors open. Wires had come the switches but still haven't sorted the drivers door (that'll be another thread)
Back on topic, can anyone tell me if the centre dash buttons are meant to illuminate when the headlights are on? Mine haven't from day one, and I haven't been able to work out if they are meant to light up?
Post #556283 15th Aug 2016 9:32pm
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
Mine all light up apart from 2 x auxilary light switches that don't seem to do anything!
Post #556370 16th Aug 2016 9:11am
mk1collector
Post #556409 16th Aug 2016 12:17pm
hunter_pa
Any idea where I can start to look to diagnose the problem? The illumination works in the main dash (speedometer, fuel, temp and clock dials). All the switches work on the centre console, and the red/orange indicator lights work for the heated seats/heated windscreen etc
Post #556517 16th Aug 2016 7:53pm
mk1collector
It's probably just the bulbs gone. Ray
My build thread
Post #556555 16th Aug 2016 10:39pm
hunter_pa
Oh? It's not individual bulbs/Leds in the acutual switches then?
Didn't get a chance to take the dash apart tonight, too busy fishing another wire for the broken dormer door wire. Took much longer than expected Confused
Post #556559 16th Aug 2016 10:46pm
mk1collector
Flip the cap off each switch where the illumination is not working and the bulb is Under the cap. Assuming your defender is a late td5 as per your profile. Ray
My build thread
Post #556576 17th Aug 2016 12:17am
hunter_pa
It's a 2005
Post #556577 17th Aug 2016 12:20am
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
How do you flip the cap off?
Alex
Post #563784 14th Sep 2016 1:21am
hunter_pa
Look like Leds under the cap, the red light works just not the illumination led. Along with every other led in the dash.
Know what wires supply what here?
Post #564538 16th Sep 2016 7:02pm
mk1collector
I think (but may be wrong) that the clear bulb is just a 5w capless bulb so should just pull out with something like needle nose pliers but I'm doubting myself now. Maybe someone else will give a definate answer. Ray
My build thread
Post #564544 16th Sep 2016 7:22pm
hunter_pa
Got the switch apart, little LED's soldering directly to the board. Will test car side connection and this tomorrow with my multimeter
Post #564559 16th Sep 2016 9:02pm
mk1collector
Well, I could have sworn they were capless bulbs Embarassed Ray
My build thread
Post #564572 16th Sep 2016 11:24pm
mustafasoleiman
Could it be that a fuse needs to be replaced in the fuse box?
Post #566026 23rd Sep 2016 11:58am
Martin
Site Admin
Where do you have illumination? Do the gauges and heater control labels illuminate?
Sounds like it could be Fuse 20 (10A) on the bulkhead fuse box - this supplies the illumination for the centre console.
The illumination is the red with orange stripe wire throughout the loom.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #566036 23rd Sep 2016 12:39pm
