![]() | Home > Maintenance & Modifications > 2.4 Turbo Problems |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
must be a underlying issue for it to go boom...
call alive up tomorrow they sorted my poorly turbo issues.. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
I'd say as above and probably electronic.
I'd recommend Alive too, Gary really does know his turbo's! You definitely shouldn't be having any issue at all as quick as that. |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
EGT to high, overfuelling (any signs of excessive black smoke) or a turbo oil feed issue. If it was the gasket or manifold you would hear a chuffing from the exhaust gases escaping and you would smell the exhaust fumes in the cab. Cure for that is either fit a copper gasket or the better solution is to get the manifold seat and turbo face skimmed.
| All times are GMT |
