![]() | Home > Maintenance & Modifications > Bumper repair |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello Huttopia
Yes...(if done well). What is the OEM treatment on the Heritage Bumper... ![]() Looks to be 'standard' issue, with a sliver painted finish (not galvanized) and black end caps. A good powder coated finish will exceed the LR paint...a two part 'hardened' paint will be better still (it's actually tough (able to take impact) not hard)...so chips (corrosion start points) are reduced. Main second area to get right is the inner cavity...for this dinitrol or similar surface treatment is worth considering. ![]() Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Thanks! You are right, it is just a standard paint finish. Having removed it I can see its not going to last long if just repainted. They will powder coat the whole thing so hopefully that will keep the rust at bay a while longer.
Best is to electrogalvanize before powder coating.
I had my rocksliders sandblasted, electrogalvanised and powder coated which costed € 5 per kg, so it is definitely worth it! Only powder coating is no good, moisture wil enter under the coating at every crack and it will rust under the coating which will eventually peel off. It is better then to do a good prep and apply a good industrial paint. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 537 ![]() |
Why not buy a proper galvanised bumper and sell the damaged one - they are cheap
I'd rather keep the original parts with it if possible.
