![]() | Home > Puma (Tdci) > MT82 drain plug - should it have a crush washer? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4296 ![]() ![]() ![]() |
There is no washer I don't think. I used PTFE tape on the threads to ensure a good seal.
No mention of a washer here...
http://www.defender2.net/forum/topic8707.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
I just use a drop or two of gasket sealant on them and the drain plug. They never leak so I'm happy with that.
AlanH. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
No washer shown on the parts catalogue.
Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25 ![]() ![]() ![]() |
Many thanks. PTFE has stopped the drain plug leaking. Just have to find out where the other leak is coming from!
Scrawf |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 784 ![]() ![]() ![]() |
Maybe replace it with a Diff Lock Drain?
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
I've just had the oil changed and they used a copper washer.
I can now say that you still have to tighten the plug correctly to stop it from leaking ![]() I tightned it to 35Nm for now (no leak so far), but the LR workshop manual says 50Nm. Would that be ok or too much for the washer? ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
What are you all using for the threads with these plugs?
Options I’m considering are; Hylomar blue universal, yellow, PTFE tape, loctite 222. Probably not the 222 as that’s a light duty thread lock, not so much of a sealer. (Doubt it would play well with oils either, but good for general jobs). Hylomar blue / yellow is very much the same thing almost. Then there is PTFE tape. I’m 50/50 between Hylomar blue and PTFE tape, probably leaning towards the latter. I see BlueST already posted regards PTFE tape. Anyone have any thoughts ? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Double post* ____\We|Will|Win/___
I don't know what my workshop used other than the copper washer. On my motorcyles a washer alone was always sufficient
![]() Regarding the torque it seems 50Nm as stated in the LR workshop manual is wrong and it's actually 35Nm - same as the filler plug. That information is from an experienced mechanic I trust and Getrag's MT82 manual. What's your experience? |
I think for the size 35NM seems about right for both fill and drain, I think 50 is too much for the drain, which is up nearer the diff plug torque which is 60NM, those plugs are much much larger in the diffs.
(Transfer box 30NM for both filler and drain). There are some errors in the WSM for sure. It’s strange that for a 2.4 puma the MT82 is stated as taking 2.4L Qty. The 2.2 Puma takes 2.2L. Despite the fact that both are the same transmission. I believe the 2.4L figure is stated as dry fill and 2.2L service fill, however, the above is stated in the WSM. Regards threads I tend to just go with the Hylomar that’s already on diff plugs, if they ever weep or any issues switch over to PTFE tape, both work without any problem at all ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
