![]() | Home > Off Topic > Advice please. Oak flooring, can it swell? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Yes indeed it can especially if there's no vapour barrier between concrete and timber flooring I would be concerned is it planks or parquet
Moles Member Since: 17 Mar 2016 Location: Wiltshire Posts: 40 ![]() ![]() |
Should be an expansion gap all around the perimeter of the room, normally concealed under the skirting board which should lightly sit on top of the flooring.
My oak floor (4m x 4m) expands a good cm Winter/Summer. Real wood expands a lot more than laminate. Moles |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
I'd be more concerned about the edges than the middle. If it expands it's strong enough to push brickwork out. I have previously had to cut up a customers one month old expensive floor because of this. V8 90...WIP
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
as all of the above have said, yes it can & ive seen it push ashlar sandstone out of place on the outside of a 4 storey Georgian grade 2 listed mansion in Winchcombe!
However - an easy ish fix, remove a skirting board on the 'long' side, invest in a combi cutter and trim 10mm off its length for its expansion and see how it goes. Keith |
Guy Member Since: 11 Feb 2013 Location: St Eval, Cornwall Posts: 250 ![]() ![]() |
Thanks for the replies. This is what I thought. If we buy it we would remodel the ground floor anyway, so would lift and refit it anyway.
Your replies are much appreciated! Guy DINGO - '99 Discovery 2 V8 with 300Tdi transplant, chawton white. Repatriated from Australia and expedition prepped. **FOR SALE** SHARKY - '06 Discovery 3 HSE Auto, bonatti grey. SOLD. GEORGE - '99 Discovery 1 300Tdi Auto, willow green. Daily driver, travel companion, part of the family! SOLD. PINGU - '96 Defender 110 300Tdi station wagon. SOLD. Dream LR - 130 pop top station wagon camper. |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1874 ![]() ![]() ![]() |
Guy, are you sure it's the oak flooring and not the concrete below being affected by something like red ash? It was used as an infill under the concrete then the sulphates react over time causing the concrete to crack and "crown" 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Assuming the house is 1980s it's a bit young for that, though still possible. I take it the floor 'bounces' and isn't solid? V8 90...WIP
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2680 ![]() ![]() ![]() |
I've installed a lot of oak flooring - always from Russwood in Newtonmore.
On concrete with a thick layer of rubber glue a new mm thick to even out the contrete and act as a vapour barrier On a suspended floor with a portanailer. Love oak flooring! Never experienced what you say - looks like you have the answers anyway... This is the rubberized glue: https://russwood.co.uk/shop/flooring/floor...-adhesive/ ![]() Click image to enlarge Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thank you all so much. I'm not actually certain if the floor is 'real' oak, but it certainly isn't laminate.
I'll be sure to have the floor carefully surveyed if we do buy, including the concrete itself and the walls. Thank you again, so much more than just Land Rover advice on here. Great forum, great blokes (and ladies!). This is the house: http://www.rightmove.co.uk/property-for-sa...miumA=true Cheers! Guy. DINGO - '99 Discovery 2 V8 with 300Tdi transplant, chawton white. Repatriated from Australia and expedition prepped. **FOR SALE** SHARKY - '06 Discovery 3 HSE Auto, bonatti grey. SOLD. GEORGE - '99 Discovery 1 300Tdi Auto, willow green. Daily driver, travel companion, part of the family! SOLD. PINGU - '96 Defender 110 300Tdi station wagon. SOLD. Dream LR - 130 pop top station wagon camper. |
