Home > Off Topic > Advice please. Oak flooring, can it swell?
Guy
Hi everyone.
Can anyone offer some advice please? My wife and I are currently house hunting. A house we like has oak flooring, looks like it is laid over the original concrete floor as opposed to being traditional floor boards as the house is fairly modern, 1980s I would estimate.
Walking across the lounge I noticed a significant hump in the floor, at least a cm high and perhaps half a metre across. The owner said she thought it was swelling as it levelled out in winter when they had the wood burner kicking out heat.
So, is this feasible?
Should I be concerned?
Can it be easily fixed?
Thanks in advance for any advice folks!
Cheers,Guy.
DINGO - '99 Discovery 2 V8 with 300Tdi transplant, chawton white. Repatriated from Australia and expedition prepped.
**FOR SALE**
SHARKY - '06 Discovery 3 HSE Auto, bonatti grey. SOLD.
GEORGE - '99 Discovery 1 300Tdi Auto, willow green. Daily driver, travel companion, part of the family! SOLD.
PINGU - '96 Defender 110 300Tdi station wagon. SOLD.
Dream LR - 130 pop top station wagon camper.
Post #550740 24th Jul 2016 8:09am
ibexman
Yes indeed it can especially if there's no vapour barrier between concrete and timber flooring I would be concerned is it planks or parquet
Post #550741 24th Jul 2016 8:21am
Moles
Should be an expansion gap all around the perimeter of the room, normally concealed under the skirting board which should lightly sit on top of the flooring.
My oak floor (4m x 4m) expands a good cm Winter/Summer. Real wood expands a lot more than laminate.
Moles
Post #550745 24th Jul 2016 8:32am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
I'd be more concerned about the edges than the middle. If it expands it's strong enough to push brickwork out. I have previously had to cut up a customers one month old expensive floor because of this. V8 90...WIP
Post #550747 24th Jul 2016 8:33am
ickle
as all of the above have said, yes it can & ive seen it push ashlar sandstone out of place on the outside of a 4 storey Georgian grade 2 listed mansion in Winchcombe!
However - an easy ish fix, remove a skirting board on the 'long' side, invest in a combi cutter and trim 10mm off its length for its expansion and see how it goes.
Keith
Post #550749 24th Jul 2016 8:42am
Guy
Thanks for the replies. This is what I thought. If we buy it we would remodel the ground floor anyway, so would lift and refit it anyway.
Your replies are much appreciated!
Guy
**FOR SALE**
Post #550750 24th Jul 2016 8:42am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Guy, are you sure it's the oak flooring and not the concrete below being affected by something like red ash? It was used as an infill under the concrete then the sulphates react over time causing the concrete to crack and "crown" 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #550763 24th Jul 2016 9:28am
Paulv8
Assuming the house is 1980s it's a bit young for that, though still possible. I take it the floor 'bounces' and isn't solid? V8 90...WIP
Post #550767 24th Jul 2016 9:39am
MartinK
I've installed a lot of oak flooring - always from Russwood in Newtonmore.
On concrete with a thick layer of rubber glue a new mm thick to even out the contrete and act as a vapour barrier
On a suspended floor with a portanailer.
Love oak flooring!
Never experienced what you say - looks like you have the answers anyway...
This is the rubberized glue:
https://russwood.co.uk/shop/flooring/floor...-adhesive/
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #550801 24th Jul 2016 11:20am
Guy
Thank you all so much. I'm not actually certain if the floor is 'real' oak, but it certainly isn't laminate.
I'll be sure to have the floor carefully surveyed if we do buy, including the concrete itself and the walls.
Thank you again, so much more than just Land Rover advice on here. Great forum, great blokes (and ladies!).
This is the house: http://www.rightmove.co.uk/property-for-sa...miumA=true
Cheers! Guy.
**FOR SALE**
Post #550911 24th Jul 2016 7:27pm
