![]() | Home > Technical > 2003 TD5 Double Cab - Running / Starting problems |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Unplug the maf and see if it makes a difference. Ray
| Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233
Try bleeding the fuel system, ignition on and depress throttle 5 times fully, elm light will flash and fuel pump will run for about 5 mins. It may be getting air in the fuel system or possibly the in tank pump.
If it's air it could be the injector seals. 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
| Skelkelly Member Since: 08 May 2016 Location: dubai Posts: 51
Thanks fellas
Where is the MAF located? Don't have manual yet! That would be ironic as that's currently the problem I have with my 900. Just tried starting it from cold, fired first time. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
next one out from air filter box
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
As has been said maf first but definitely worth doing injector seals and washers as when these go it lets fuel run back and if your getting a white puff of smoke on start up usual a good sign of the problem 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
| Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 850
When reversing particularly with a trailer or up a slope I used to stick my old td5 in low box, I found it a lot better.
One thought with you being on a slope is fuel level, my disco td5 which is parked on a slight slope would not start if the fuel light had been on for only 10 or so miles when parked. The pump was a bit lazy so I went for a new genuine one, found the old pump was a non gen and heard of a couple of times that non gen pumps all seemed to do the same when running low on fuel |
Disconnected the MAF and bled the fuel pump, made no difference
Very rough on idle, lots of white smoke. Head gasket? |
| taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663
I wouldn't jump to HG just yet. Check Injector seals and also stick your hand behind the FPR. Check for any leaking etc. Or clamber underneath and check with a torch down behind and below where it sits.
Generic thought process for white smoke IMO of course: Low Fuel Pressure (anything from Pump, to Seals) Faulty Glows (though the TD5 doesn't have such a requirement on glow plugs as some diesels IMO ...) Possibly Turbo Issues Low Compression (this is a last option if all else doesn't fix it) Few other bits and bobs, but not usually TD5 issues. Out of interest, have you checked for oil in loom in case your injectors are getting dodgey signals? Are you a 10P or 15P engine (Assuming 15P on a 2003, though still plenty of reasons it could be a 10P in 2003)? I'm going to go with fuel somewhere along the line. Last edited by taazzukcb on 21st Jul 2016 8:45am. Edited 3 times in total |
fuel presser regulator leak , driver side back engine, ruff idling can all so be oil in red ecu plug, stronger smell of exhaust gasses, did it small of diesel ?
you six mouth warranty 2003 engine 15P ease way to check do you have pipe running from the fuel presser regulator to the front of the cylinder head this fuel retune from injectors on 15p engine fuel system |
Just to say, of all the car forums I've been a member of over the years, this really is the best in terms of the depth of knowledge you guys have!
Thanks all, I'm getting into my local garage today / tomorrow for testing so will report back and pass on our comments! |
Check for oil in the red ecu plug Ray
I looked at the ECU earlier in the week and all looked dry, will check again though.
Red plug...
Click image to enlarge |
