Home > Maintenance & Modifications > Land Rover Light Guards Questions
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
Hi Folks,
Thinking of getting the official LR light guards for the front and back and had a few questions:
1) Will they fit, especially the back ones, with WIPAC LED lights?
2) If in the future I add a Nakatanenga wheel carries, will the rear lamp guard fit ok? If not, can it be modded? If so, any pictures?!
3) I'm assuming as the front ones have a fair bit of space, they will fit ok with LED lights?
If anyone has a white Defender with a silver grill and light surrounds with the guards fitted, front and back, I'd really appreciate a photo or two if it's not too much hassle Smile
As always, many thanks!
Edzi
Post #549503 18th Jul 2016 11:03am
Cupboard
Are you talking about the mesh grilles that cover over everything?
Like this?
If so, I think you could probably do a lot better, they're not very good.
Post #549518 18th Jul 2016 12:51pm
gilarion
I have OEM rear light guards and they fit fine with WIPAC LED�s. Both the front and back guards are black nylon coated, so no nasty powder coat to peel. On one of my Defenders they have been fitted for seven years and look as good today as they did when I first fitted them.
Just make sure they are genuine as there are a lot of cheap copies out on the market and those are just sprayed black or powder caoted and they will rust. OEM's are not cheap but the extra is well worth the money. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #549525 18th Jul 2016 1:01pm
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
Hi Edzi
I have all that you have asked for and it all fits fine Thumbs Up
 Life is one big adventure, that's why we have the vehicle for the journey.
Post #549526 18th Jul 2016 1:04pm
Edzi
Thank you all for your replies; much appreciated Smile
Cupboard, yup, those ones. Open to suggestions if you have something better in mind.
Gilarion and Mr Baldylocks, perfect, thanks Smile
Post #549530 18th Jul 2016 1:19pm
gilarion
If it is of any help Travall are the makers of OEM light guards and you can buy direct from them with free postage.
https://www.travall.co.uk/land-rover/defen...agon-2007-
Post #549532 18th Jul 2016 1:31pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I have the Equipe headlight guards fitted as here https://www.trekoverland.com/collections/e...4x4-gf0046 For these you dont have to drill the bodywork above the headlight surround, so if you ever need to go back to standard just fit a replacement surround and you will never know they had been fitted.
Post #549534 18th Jul 2016 1:34pm
Edzi
Thanks Smile
Post #549550 18th Jul 2016 2:40pm
Edzi
Cheers Smile
Post #549551 18th Jul 2016 2:40pm
Happyoldgit
In 4 decades of Land Rover use in various conditions and Land Rovers I can't think of one occasion where a headlamp guard would have saved a headlamp but can remember one or two instances where guards have caused additional damage to panels. TBH I found them a hindrance to maintenance especially as the fixings corrode and would not contemplate having them fitten again. Steve.
http://forums.lr4x4.com
Post #549556 18th Jul 2016 3:10pm
gilarion
I have used stainless for all the fitting with a little copper grease added to the threads, part of the rear fixing are plastic so nothing to worry about if you use the right stainless bolts. The rivnuts are brass so they are OK as well. I have also used security headed stainless bolts to make taking them off by thieving scumbags much more difficult. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #549573 18th Jul 2016 5:04pm
Edzi
Thanks for the feedback Steve and Gilarion. Much appreciated.
Post #549627 18th Jul 2016 9:34pm
Cupboard
Yes, I've had issues with mine and I don't see the point. Had bits of tree stuck in the front ones too.
They were all put on by the previous owner's dealer and the job was done incredibly badly which tarnishes my opinions rather too.
Post #549628 18th Jul 2016 9:39pm
leeds
Hi Edzi, taking up point 2 of your opening post.
There is no straight forward answer about will a spare tyre on a swing away wheel carrier touch a light guard or not.
It depends on actual tyre diameter and how much the wheel carrier is set off centre.
There is a possibility that you could position a rear door gas strut so that it limits the opening of the door so spare tyre does not foul on light guard.
Brendan
Post #549640 18th Jul 2016 10:45pm
mse
Front light guards have a number of uses and don't get attributed to too much damage, but I've never heard of the rears being any point other than to cause damage.
That said the bolt on bits ones are slim and cool Mike
Post #549647 18th Jul 2016 11:17pm
