![]() | Home > Puma (Tdci) > Rattle when slamming driver's door? |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
Only a couple of hours ago ........
http://www.defender2.net/forum/topic47786.html |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1771 ![]() ![]() |
Well spotted Greeni
![]() Just be careful when removing door card as the clip retainers are made of playdoh if you decide to investigate the rattle yourself. I chose to because I didn't want the door card destroying. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2274 ![]() ![]() |
There was never a defender door that didn't need SLAMMED. The rattling isn't from the door but from your inner ear drum making contact with the side of your skull. It just wouldn't be right for the door to have a gentle smooth clic action .
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3855 ![]() ![]() |
Very easy to take apart to have a look,
While your at it fit some silent coat and then it shuts with a thud and not an empty tin can ![]() ![]() Click image to enlarge |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 ![]() ![]() ![]() |
The handles on both my doors are coming loose and you can see the securing thread poking out of the door panels.
It would be a 5 minute fix if the door cards were not there. As they are i can see it being an hour or two and broken clips and trim.... |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
It's not that much drama - in saying that, it is easier once you know how it's all held together... Solved the bowel problem, working on the consonants...
