- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
ginjez
Just removed door card and foam sheet to try and find the source of annoying rattle from within the door -mostly when closing the door . Turned out to be the rod connecting pull handle to latch vibrating against inner door skin. A self adhesive clip had detached itself from the door which acts as a spacer. My solution - two small rubber grommets placed around latch rod and now no more rattle
10th Jul 2016 2:16pm |
