Home > Technical > TD5 Rev counter install |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
I am pretty sure td5 ecu outputs a 4cylinder square wave pulse. All you need is a circuit to boost the 0-5v signal to 12v. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
8th Jul 2016 10:54pm |
Telshe Member Since: 02 Jul 2015 Location: West Oxford. Posts: 49 |
Include me as well.
Telshe |
20th Jul 2016 3:36pm |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 227 |
It's not really a 0-5V signal, the ECU output has a particular characteristic that you need to match. But a 4-cylinder rev counter works perfect. I'm using this model: Vision Black 4,000 RPM Tachometer - VDO 333-156 with some glue electronics Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
20th Jul 2016 10:12pm |
GerardTd5 Member Since: 03 Aug 2016 Location: almost Germany Posts: 44 |
Hi Peter, I'd like to know how you've succeeded. A schedule, a manual and material list is more than welcome.
GerardTd5 |
3rd Aug 2016 9:26am |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 218 |
PLus 1 for that - now who's going to ask Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
3rd Aug 2016 8:29pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Dan is away until the 9th, I believe
4th Aug 2016 5:46am |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 |
Can you put a rev counter on a 300tdi? 300tdi 90 1996.
4th Aug 2016 10:41pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
I think the 300tdi alternator has a W terminal - I'd so then there is a whole raft of aftermarket rev counters that would just for straight on.
5th Aug 2016 7:34am |
Sorry for the spelling - can't edit in the mobile version.
5th Aug 2016 7:35am |
Thanks Anderzander. Will take a gander. 300tdi 90 1996.
6th Aug 2016 4:35pm |
jnglmstr Member Since: 03 Aug 2015 Location: Dorking - Surrey Posts: 14 |
Hi Peter, would you care to share your experiments / schematics with us please? Thx!! |
25th Aug 2016 9:56am |
Still no schedule, the vdo rev counter Peter used is a 4000 rpm one. Td5 engines max is 4850, if I remember correctly.
Cheers, Gerard90Td5 |
13th Aug 2017 12:53pm |
klacinak Member Since: 11 Jul 2019 Location: Kunhegyes Posts: 8 |
@Peter
Hi Peter, is there an available schematics for your solution? I have the same problem with my TD5. Thank you!!!! Laszlo
11th Jul 2019 5:02pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2233 |
You may be interested in this https://www.defender2.net/forum/topic65167.html > 110 XS Double Cab
> Instagram @simonlanemind |
11th Jul 2019 5:46pm |
