![]() | Home > Puma (Tdci) > Oil leak? |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Check the swivel seals.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Yup, that was my first thought, but obviously front only...
Take a look on the inside face of the front tyres, should be radial patterned drips. And gunk around the bottom of the swivel balls. Solved the bowel problem, working on the consonants... |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 ![]() ![]() ![]() |
These are rear tires by the way..
Diff oil making its way along the shafts?
A few seals/systems in the way, but it is possible. Your brakes are working right? Solved the bowel problem, working on the consonants... Last edited by agentmulder on 30th Jun 2016 9:47am. Edited 1 time in total |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 805 ![]() ![]() ![]() |
Maybe inner hub oil seals. One went recently on mine and the oil seemed to get everywhere on the back wheel. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
Clean it off, park it on a slope, see what you get.
Also check level of oil in the diff (flat surface again, dunk your little finger in the filler). Solved the bowel problem, working on the consonants... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17869 ![]() ![]() ![]() |
Hub oil seal. You need to sort it since the brake disk and pads will be saturated and ineffective.
FTC4785
https://www.landroverworkshop.com/diagrams...ts_44802#9 Solved the bowel problem, working on the consonants... |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Drive Member Cap? Take a picture with the wheel removed. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
Is it not FTC5268, the stub axle seal? As far as I know diff oil shouldn't be getting through to the hub and bearings in any large quantity.
Apologies, yes I think you're quite right.
The part description threw me. Solved the bowel problem, working on the consonants... |
Thanks guys .. Will let you know what exactly is the problem..
Yep, hub inner oil seal or possibly drive member dust cap. That said it would have been just as quick to whip the wheel off and find out for certain. Steve.
