Home > Puma (Tdci) > Oil leak?
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Oil leak?
Hi I've been noticing this patch of oil on my wheels last few weeks.. Can anyone help me identify the problem..
Thanks in advance.
Post #544712 30th Jun 2016 5:22am
williamthedog
Check the swivel seals.
Post #544714 30th Jun 2016 6:24am
agentmulder
Kuwait
Yup, that was my first thought, but obviously front only...
Take a look on the inside face of the front tyres, should be radial patterned drips. And gunk around the bottom of the swivel balls. Solved the bowel problem, working on the consonants...
Post #544716 30th Jun 2016 6:32am
Arsath
These are rear tires by the way.. Smile
Post #544727 30th Jun 2016 8:03am
agentmulder
Kuwait
Diff oil making its way along the shafts?
A few seals/systems in the way, but it is possible.
Your brakes are working right? Solved the bowel problem, working on the consonants...
Post #544729 30th Jun 2016 8:08am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Maybe inner hub oil seals. One went recently on mine and the oil seemed to get everywhere on the back wheel. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #544730 30th Jun 2016 8:09am
agentmulder
Kuwait
Clean it off, park it on a slope, see what you get.
Also check level of oil in the diff (flat surface again, dunk your little finger in the filler). Solved the bowel problem, working on the consonants...
Post #544731 30th Jun 2016 8:11am
Hub oil seal. You need to sort it since the brake disk and pads will be saturated and ineffective.
Post #544754 30th Jun 2016 8:51am
agentmulder
Kuwait
FTC4785
https://www.landroverworkshop.com/diagrams...ts_44802#9 Solved the bowel problem, working on the consonants...
Post #544767 30th Jun 2016 9:52am
nickhodgson
Drive Member Cap? Take a picture with the wheel removed. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #544768 30th Jun 2016 10:00am
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
Is it not FTC5268, the stub axle seal? As far as I know diff oil shouldn't be getting through to the hub and bearings in any large quantity.
Post #544931 30th Jun 2016 9:21pm
agentmulder
Kuwait
Apologies, yes I think you're quite right.
The part description threw me. Solved the bowel problem, working on the consonants...
Post #544934 30th Jun 2016 9:32pm
Arsath
Thanks guys .. Will let you know what exactly is the problem..
Post #546295 5th Jul 2016 7:34pm
Happyoldgit
Yep, hub inner oil seal or possibly drive member dust cap. That said it would have been just as quick to whip the wheel off and find out for certain. Steve.
http://forums.lr4x4.com
Post #546309 5th Jul 2016 8:02pm
