Home > Technical > Webasto thermo top v
The Monkey
Ireland
Hi all,
I managed to blag a thermo v heater from a Range Rover sport yesterday, included is the unit, exhaust, air filter, part of the fuel line and the loom.
I'm quite happy to run it of a switch as a opposed to a timer for the time being. Has anyone retro fitted one to a td5 using the Range Rover loom and if so could you share your experiences with me. I'm led to believe that I may have to buy an auxiliary fuel pump. All info appreciated.
Post #542324 22nd Jun 2016 10:53am
Martin
Site Admin
You need the fuel pump for it, and you cannot trigger the TT-V from a simple switch.
It can only be fired over the WBUS connection, which is a communications bus between the heater and controllers. The cheapest way to do this is with the Webasto 1533 timer.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #542333 22nd Jun 2016 11:18am
The Monkey
Ireland
Thanks for the reply, why can't things be simple if I buy the webasto 1533 timer do I have to buy it with a specific loom. I see there advertised for a good few German cars.
Post #542337 22nd Jun 2016 11:36am
Martin
Site Admin
If you can do wiring I sell all the bits to make a loom, but not looms themselves.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #542338 22nd Jun 2016 11:38am
dgardel
Italy
http://www.defender2.net/forum/post49777.html
http://www.defender2.net/forum/topic10368.html
and look inside here https://1drv.ms/f/s!AnHBx4Wc2MJLhHCJHV4kSP-fcW6w Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #542609 22nd Jun 2016 11:30pm
