![]() | Home > Puma (Tdci) > My manual for a DIY WEBASTO WATER HEATER on PUMA |
wrote right now..........
https://1drv.ms/b/s!AnHBx4Wc2MJLh0w1W5Rpcxh03xuM what do you think about my work? My Webasto still not installed yet.......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 22nd Jun 2016 11:28pm. Edited 2 times in total |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2146 ![]() ![]() ![]() |
Hi Danielle
great stuff... I'll be refering to it when we get arround to fitting one later in the new year... Festive best wishes G&J (mind you - we could do with it this week as its minus 10 here at the moment!) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
Looking good. Are you planning to use the webasto external temp sensor as well for full auto mode operation the same as the d3?
I would find this really useful as the puma actually cools down when used stationary or at low speeds in sub zero weather. Oh and how much to fit a system to mine !! Great work. Pom edited: iphone typing ftl. Last edited by pom on 26th Dec 2010 11:30am. Edited 1 time in total |
I'm thinking to use the existing fuel tank adding the small metal pipe installed on the white Defender fuel tank plate Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
if you install the temp sensor (it is a temp controlled switch, ON for temp under the 5°C and OFF when the temp rise up the 8°C) you can not switch on the heater when temp is 5°C or more. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Hi Gary, Hi July Merry Christmas. hoping that y document will aid you..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
...........and, it is only the rev 0.0 of the document....
it will improved on the next days..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
mhmmm I think that the cost for the "travelling allowance" are too high...... I'm not competitive in UK ![]() ![]() ![]() ![]() may be I'm looking for a local company and sign a subcontract for UK operations..... ![]() ![]() ![]() IID Pro MV License |
another master piece dg
![]() 1968 1/32 scale Britains 109 Pick up. |
au contraire! Sounds like a good excuse for a defender convey to the continent. Pom |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
I'd be interested to see if there are any problems after you have been wading - particularly water getting into the exhaust system or problems with the electrics
Looking at fitting one with the winter fast approaching. Do you know at what coolent temp the webasto turns off ? Pom |
105°C inside heater chamber.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Thanks
