![]() | Home > Puma (Tdci) > Center dash lights fuse? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17938 ![]() ![]() ![]() |
No separate fuse, as I recall, but it can be a right pain getting the bulb to seat correctly in the holder. There is also a connector between the heater control lights sub harness and the main dash light harness, if this is dislodged you'll have no heater lights.
You may also find that those bulbs can overheat when failing and damage the uber-expensive heater control panel. ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
O.K. then tell us "HOW DO YOU KNOW?"
![]() ![]() Seriously though, sorry for your misfortune. These things can be a pain in the neck ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
All sorted! They all just needed a gentle push right home, now all four working.
The Lucas part number is LLB286, they are 1.2w capless bulbs on a 2011 puma, not the 501 capless as metioned somewhere else on the forum. |
I know because one cold wet night I couldn't turn the b****y fan off speed 3 after demisting! The bulb for the fan switch had melted the backside of the panel to such an extent that the slider was stuck.
That panel is something like £500 too, it went up from around £80 about a month before I needed one. ![]() In the end I reshaped mine and it has been ok since, though intentionally I have left that bulb out. |
