![]() | Home > My Defender > Im going to build a new TDV6 3.0L defender, need ideas. |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
110 utility puma on tibus portals and an auto.....
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 ![]() ![]() ![]() |
I've got a nice 2010 puma 110 USW that I'd happily let you install it in
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
i think the clutch wont survive that torque and user misuse |
geckos Member Since: 18 Mar 2010 Location: queensland Posts: 16 ![]() ![]() |
[quote="Alexke"]
i think the clutch wont survive that torque and user misuse[/quote It's the one out of the disco3 gearbox and engine |
I presume you are refering to the Defender clutch. 130's have feeling's as well you know ![]() |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
Disco clutches don't last either
![]() XS 110 Utility maybe one day..... (did they fix the quality yet?) |
oh ok, you would think LR would make something to match the vehicles torque and power. |
nope i meant a 2.7TDV6 D3 clutch... so a 3.0TDV6 has more torque or does landrover supply a manual for the 3.0TDV6? Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Well ive ended up with a donor car, it just so happend to turn up at the right time and price so if my plans turn out i can make it work.
Its currently a TD5 110 defender county station wagon with a full internal P&P role cage, 4x bucket seats compertition harneses, floor safe, expidition roof rack Goodridge MTR tyres etc etc. Ill be working on the car its self to get it how i want it minus the engine transplant first, and as said if my plans work out and i dont loose incentive ill hope to give it a transplant some time in the middle of the year once the rest of the car is how i want it and after ive done the developement work on the engine etc etc. Ill post a few pics of the car as i can. Pete |
Here is a few pictures of the defender i have to start my project with.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
555SUB Member Since: 21 Feb 2009 Location: Shropshire Posts: 17 ![]() ![]() ![]() |
Shame you have sorted a Defender for your engine project as I have a new fully galvanised puma 110 chassis and was hoping to fit a 2.7 TDV6 engine and marry it to an auto box.
On a separate note.... When you converted the TD5 to TDV6 did you have to modify the engine mounts much.......... as once I have a rolling chassis was hoping to visit you and gather best way of fitting TDV6 either by you / your company doing the work or advice. Look forward to seeing your comments. |
The engine mounts i made for the TDV6 conversion by cutting the old TD5 mounts of and welding some made ones to the chassis.
Pete |
s18mcn Member Since: 11 Feb 2011 Location: cambs Posts: 53 ![]() ![]() ![]() |
Arent NENE overland building a 10reg 110 puma based 3.0 TDV6 at the mo?
Yes it's nearly done.
