Home > Maintenance & Modifications > Secure Fuel Recess Cover?
Alun
United Kingdom 2011 Defender 90 Puma 2.4 PU Santorini Black
Hi all,
I'm sure I've seen one of these somewhere before but can't find it when I need it! So here goes - please can anyone help me with sourcing this modification?
I'm looking for a lockable door/cover that converts the recess created by the fuel filler cap into a little cubby hole. Its important that it has a numbered barrel to lock (no keys) - does such a thing exist?!
Many thanks in advance of any replies
Post #542088 21st Jun 2016 4:28pm
shaggydog
You can get a thing called a Defendoor but it isn't lockable and just clips into place until it is stolen, blows off, or left at a diesel station.
There isn't much point in armoring the fuel filler point because if someone wants to steal the fuel they can cut the huge rubber pipe under the wing and siphon it out. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #542369 22nd Jun 2016 12:55pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
I've seen a homemade version of what you mentioned in the past. I think it was a hinge and flap inner frame from a Range Rover classic, with a piece of ally cut to fit the Defender aperture stuck over it.
Nothing a few rivets and some ally can't fix, but is it really worth the hassle!? Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #542372 22nd Jun 2016 12:58pm
Or punch a hole in the plastic tank and put a bucket underneath.
Defendoor is useful for keeping mud and grot out of the recess.
Post #542423 22nd Jun 2016 3:10pm
Alun
Many thanks for the replies guys
It's not to save fuel theft. To add a bit more detail, we are a rescue team and have the need to leave keys locked on vehicles when out on jobs so that the vehicle can be moved or accessed by someone other than the original driver. We have lockable key safes already but this can be fiddly to use especially when the weathers foul. I thought I'd seen somewhere a "conversion" flap which makes a lockable cubby hole out of the filler recess. The search goes on I guess...
Post #542501 22nd Jun 2016 7:23pm
Be aware that most of the readily-available combination key safes can be opened remarkably quickly with no damage whatsoever, especially the kind with push buttons. The kind with rotating dials take a couple of minutes longer. I wouldn't trust one as far as I can throw it.
Post #542505 22nd Jun 2016 7:28pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Have you thought about the wing top locker that fits into the blanking plate on the wing.
http://www.mudstuff.co.uk/gmb-fender-locker.html
Not cheap but might do the trick. Obviously it is a keyed lock but looking at it there may be the possibility of getting suited locks so that one key works on all. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #542514 22nd Jun 2016 7:55pm
leeds
Hi Alun, it is much easier to answer with more information that you have supplied.
Forget the fuel cap area as that is just likely to give you grief in having one made.
Go to the Mudstuff website, what you need is the Fender Locker by GMB. Fits into the wing top O/S where the blanking plate is. Have a look here
edit to add great minds etc Phil. You just beat me to it!
Brendan
Post #542515 22nd Jun 2016 7:59pm
Alun
Thanks all again. The Fender Locker looks ideal but the key makes it totally impractical - it has to have a combination lock.
Post #542598 22nd Jun 2016 10:53pm
Stacey007
Could you get more keys cut for possible drivers?
Or how about a metal magnetic box of some sort hidden under the car somewhere? Don't think anything ideal in bad weather / dark
I would also worry the combination would stick in winter.
Post #542605 22nd Jun 2016 11:09pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
If i know the rescue services, it's more about getting to any vehicle at any point...in a calm rush... if you have six vehicles, that's 6 keys..and you need the first vehicle that you come to...
we should be able to find someone who can put a hoop in both the moving top fender wing door and the fender itself in order to put a combination lock through it?
Post #542610 22nd Jun 2016 11:37pm
Alien
Australia
I just did a quick eBay UK hunt and found a lock that could be fitted to the Mud locker.
http://m.ebay.co.uk/itm/301806371582?_trkp...0617704907
An alternative could be something like this?
http://m.ebay.co.uk/itm/Secuirty-Combinati...iid%253A10 Cheers,
Kyle.
Post #542617 23rd Jun 2016 12:19am
rockhound42
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Something like this on the fender locker instead of or along side the the key lock?
http://www.ebay.co.uk/itm/YALE-COMBINATION...XQgb1RTvX4
or fasten a key safe on the outside somewhere?
http://www.ebay.co.uk/itm/Yale-Y500-Combin...SwmtJXatOH
Not secure one deleted!
could find a uk sellar for this? Would need the matching receiver too.
https://www.amazon.com/HitchSafe-HS7000T-H...amp;sr=8-1
Post #542654 23rd Jun 2016 8:55am
Beware the second key safe in the link above can be opened in minutes, it is really not secure.
Post #542665 23rd Jun 2016 9:45am
