![]() | Home > Maintenance & Modifications > bmw 3.0 into a defender. .... |
I'm certainly no specialist, but it's something I'd love to do as well. Initial thoughts are would it not be better to get a little bit of info from Nene/Bowler/Twisted who have all made similar upgrades? If only to recommend what would be the best engine? Most seem to stick with Chevvy or JLR powerplants. Surely a Beemer would be even more techy with a lot of unnecessary cross-pollination of brands and parts etc? Good luck anyway, will be interested to see your progress.
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
s410man Member Since: 20 Jun 2016 Location: brecon Posts: 3 ![]() |
From what I've learnt it appears to be quite a simple engine with a off the shelf loom available to make it run properly
M57 engine is what i would like but there's a few different types of them!! Twin turbo any more difficult to do or.... |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
3.2 tdci 2.2/2.4 big brother pretty much straight fit 240hp 700nm
Simples ![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
^ is that a 3.2 out of say the new ford Ranger?
What other model has it fitted? |
Wandathe110 Member Since: 10 Apr 2016 Location: Manchester Posts: 65 ![]() ![]() |
There's a company that does a conversion kit for the Mercedes 3ltr I'm pretty sure there a v6 and a conversion for a 5 cylinder 2.8 both have been mated to auto boxes all i need to do is remember where I've seen it
![]() http://www.gaz-fab.co.uk/node/23 Got to go game of thrones to watch ![]() |
Transit is the engine needed 2015 2.2 tdci hardtop xs
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
W110 the article you saw was in one of the LR mags, it was for the straight 5 cylinder in the disco 2 and the straight 6 in the Defender
LRO where i seen it looked really interesting
See link. http://www.gaz-fab.co.uk/node/23 |
Andrew*Debbie Member Since: 25 May 2016 Location: Anglesey Posts: 95 ![]() ![]() |
How about an old BMW M30? They are rock sold with no plastic parts to break. The M30 is good for 200,000 to 300,000 in a BMW 5 or 7 series. Stock they peak out around 200HP but can be modded for more.
The newer motors are more powerful and lighter but have a lot of plastic that only lasts about 7 years before failing at the most annoying intervals. Water pipes and the thermostat housing are the biggest problem but I'd be careful about a recycling a used intake manifold too. You also have to contend with variable valve timing (VANOS) on the newer motors. It is great when it works and is fairly solid. VANOS from a scrap yard motor could be trouble. The M30 5 and 7 series used a ZF 4 speed. I know I've seen a Defender with a ZF 4 speed in it. If you want a newer motor (M30 is about 25 years old) how about the N52 or N53, the last of the naturally aspirated inline-6 BMW motors. These motors are light and have a magnesium block Both are good for ~270HP if you find the right variant. Look for a 330i or something with 3.0si in the name. Last edited by Andrew*Debbie on 22nd Jun 2016 2:32pm. Edited 1 time in total |
The Hulk Member Since: 13 Apr 2016 Location: Aberdeenshire Posts: 81 ![]() ![]() ![]() |
The M57D30 was used in the Range Rover so you'd be doing an RR-LR transplant. The M30 is a wonderful engine but it's a petrol. I have two cars with this engine; one has twin turbos and puts out 520Nm of torque ![]() Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
Of course. Using a RR motor could make things easier, especially if the transmission can be make to work in a Defender.
There are also the rare South African Defenders that came from the factory with a BMW petrol M52. |
muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122 ![]() ![]() ![]() |
To put a spanner in the works, back in my cobra kit car days, a popular, under used transplant was the Lexus LS400.
Lightweight, bomb proof & easy to set up auto or manual - come by very cheaply, the only disadvantage being a big rusty car attached! just a thought..... Richard Defender 90 SVX |
......assuming you don't mind going to petrol of course
![]() Defender 90 SVX |
In effect what Bowler did with ther DC. A JLR 4ltr unit from the F Type, which I assume would be the same used in the RR Supercharged, and using the F Type 7-speed auto transmission. 440bhp. Even the twin under slung exhausts are from the F Type. If I had the money...... ![]() ![]() Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
