![]() | Home > Technical > Turbo spooling down |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2516 ![]() ![]() |
I let it spool down after a 60 mile commute every day, specially if its been on the limiter!
![]() ![]() 2015 Discovery 4.5 Black pack Firenze red XS |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
If I were doing 70mph down the motorway and then did an emergency stop I reckon it would be worth waiting.
had I just slowed down, parked up etc then no as I suspect it's pretty much down to speed anyway. As I don't do 70mph on the motorway I won't be worrying too much. |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I have never felt the need and hence never bothered, I've never had a problem with a turbo over a good many years of turbo diesel vehicles.
The fact is that pretty much all modern small vehicle turbos have a very low rotating mass and when trying to create pressure in the system, the mechanical inertia is lost very quickly once the exhaust gas stops flowing and the outlet pressure path is effectively closed off. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Apparently as long as its had a few moments not spinning like a crazy thing, there is no need.
So if you pull up and reverse in or slow down and position yourself in a space, its ok to switch off and walk out. If you had been hooning it around, did 70 stopped straight away, then yes give it a few seconds. Mike |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
It's not spooling down that's the problem, it's cooling. Always let them run for a minute or two after a drive to let it cool. Otherwise what happens is oil gets toasted onto the spindle and bearing. Bad news. High temperature shutdowns are the biggest killer of turbos
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Its more important in petrol turbo cars which have much hotter exhaust gasses. If the heat is not allowed to reduce, you can cook the oil in the turbo, which can cause it to block the oil paths.
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
I make a habit of driving gently and mostly off boost for the last few minutes of a journey.
If I've been hooning around then I'll let it sit a few minutes |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2290 ![]() ![]() ![]() |
I always let it slow/cool down. Just a habit really, and not a bad one.
It's not a big deal for me to hang on a minute or two whilst I engage the handbrake, put it in gear, close the flaps and switch everything else off. ![]() |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
turbo or both I always drive steady at the beginning and end of every journey, I've had several petrol turbo charged audi's each with over 180k miles on them and a few turbo diesels. I've never had a problem.
I only leave them running if I've been towing or had them under load and the turbo has been spooling up. I've never had a new turbo or turbo related problems in 20 yrs of driving 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
I always let the turbo warm up before any harsh acceleration and always let it spoil/cool down with a few mins at idle
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
so clearing a fault by turning the engine off and on again whilst driving along the motorway isn't good then?
I have to say I do usually let it sit for a little before turning off, not ages but so the turbo isn't running. |
No not good
