Home > Technical > Turbo spooling down
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Turbo spooling down
I was speaking to a guy the other day after he had pulled up next to me at Cholmondely Castle. He pulled up in an almost new Defender and immediately switched off the engine. I asked him how far he had travelled and said around 70 miles. I said do you not let the engine idle for a short while to let the Turbo spool down, he said "No he never has done".
I was always taught to let the turbo spool down especially after a long run. I wonder how many other folks just switch off after doing a long hot run? Rolling Eyes
Post #539560 12th Jun 2016 10:21am
Welshsurferdude
Wales
I let it spool down after a 60 mile commute every day, specially if its been on the limiter! Mr. Green Whistle 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #539563 12th Jun 2016 10:49am
Caterham
If I were doing 70mph down the motorway and then did an emergency stop I reckon it would be worth waiting.
had I just slowed down, parked up etc then no as I suspect it's pretty much down to speed anyway.
As I don't do 70mph on the motorway I won't be worrying too much.
Post #539568 12th Jun 2016 11:26am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I have never felt the need and hence never bothered, I've never had a problem with a turbo over a good many years of turbo diesel vehicles.
The fact is that pretty much all modern small vehicle turbos have a very low rotating mass and when trying to create pressure in the system, the mechanical inertia is lost very quickly once the exhaust gas stops flowing and the outlet pressure path is effectively closed off.
Post #539571 12th Jun 2016 11:44am
mse
Apparently as long as its had a few moments not spinning like a crazy thing, there is no need.
So if you pull up and reverse in or slow down and position yourself in a space, its ok to switch off and walk out.
If you had been hooning it around, did 70 stopped straight away, then yes give it a few seconds. Mike
Post #539577 12th Jun 2016 12:06pm
Fatboy Slim
Wales
It's not spooling down that's the problem, it's cooling. Always let them run for a minute or two after a drive to let it cool. Otherwise what happens is oil gets toasted onto the spindle and bearing. Bad news. High temperature shutdowns are the biggest killer of turbos
Post #539585 12th Jun 2016 12:32pm
Hufflepuff
Its more important in petrol turbo cars which have much hotter exhaust gasses. If the heat is not allowed to reduce, you can cook the oil in the turbo, which can cause it to block the oil paths.
Post #539588 12th Jun 2016 12:45pm
miker
I make a habit of driving gently and mostly off boost for the last few minutes of a journey.
If I've been hooning around then I'll let it sit a few minutes
Post #539589 12th Jun 2016 12:45pm
Screbble
I always let it slow/cool down. Just a habit really, and not a bad one.
It's not a big deal for me to hang on a minute or two whilst I engage the handbrake, put it in gear, close the flaps and switch everything else off. Thumbs Up
Post #539598 12th Jun 2016 1:12pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
turbo or both I always drive steady at the beginning and end of every journey, I've had several petrol turbo charged audi's each with over 180k miles on them and a few turbo diesels. I've never had a problem.
I only leave them running if I've been towing or had them under load and the turbo has been spooling up.
I've never had a new turbo or turbo related problems in 20 yrs of driving 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #539603 12th Jun 2016 1:48pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I always let the turbo warm up before any harsh acceleration and always let it spoil/cool down with a few mins at idle Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #539626 12th Jun 2016 2:42pm
Cupboard
so clearing a fault by turning the engine off and on again whilst driving along the motorway isn't good then?
I have to say I do usually let it sit for a little before turning off, not ages but so the turbo isn't running.
Post #539685 12th Jun 2016 7:42pm
Fatboy Slim
Wales
No not good Laughing and the turbos always spinning if the engines running.
Post #539697 12th Jun 2016 8:04pm
