Home > Maintenance & Modifications > Patriot or Hannibal group buy
Sign Up
(2)
(2)
User Registered Confirmed
TC7th Jan 2011 12:22am
BBSJK7th Jan 2011 11:56am
BigRuss6th Jan 2011 10:17pm
SteveS8th Jan 2011 11:16pm
Page 5 of 5 <12345
leeds
Agree and disagree with Alan.
Don't use WD 40 use a lubricant, preferably silicon based which is what I believe Patriot recommends and what I use
A roof rack will help in the event of a roll over. Draw a line from the edge of the bonnet and top of the B pillar. Yep the drivers head will be in the firing line The windscreen holder/A pillar is not that strong and in the event of a roll over bonnet tends to hit ground first as a lot of weight is in the engine compartment. Then front of roof! A roof rack helps spread the impact and helps prevent the front of the cab from being crushed. Not that I have experienced anything like that Embarassed Whistle
As Alan said both racks are good ones, so down to personal preferences really
Brendan
Post #53796 18th Jan 2011 11:02pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Good point on the WD40. That's what Karl and I used when we put mine together but we were doing it without access to much other than what I had to hand in the car.
You'd be better off with a proper lubcricant (although WD40 did seem to work).
Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #53812 19th Jan 2011 8:07am
Urban Magik
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Belize Green
Sonic3d wrote:
How about this for an option to hold up a patriot rack Whistle could be persuaded to part with it....
Hi
I know its an old post but love the rack combo , can you tell me the name of the rear roll cage and where I might find one?
Thanks
Vern
Post #897123 10th Apr 2021 12:43am
Smyles_
Denmark
Had a quick rummage through his posts but couldn't find anything leading to a definitive answer. Going off the connections solely, your best bets are either Safety Devices or Protection & Performance. I'd be leaning to the latter given the hoops flatter bend pattern of the upper bar though. Confused
Might be worth shooting both an email and asking if they ever produced one. Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #897124 10th Apr 2021 2:15am
It was a one-off made by Sonic3d himself. It wasn't a roll cage (it attached to the tub only) just a structure to support the rack. He eventually sold it to someone on this forum but I can't remember who.
Post #897148 10th Apr 2021 8:38am
Page 5 of 5 <12345
