![]() | Home > Maintenance & Modifications > From simple Puma 110 HardTop to PopTop Overland Camper |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
Yes,exactly.But only if you keep the origional length shocks.
If you fit +5.5" or greater shocks,they won't top out before the bump stops are reached. Marc. |
Simon.pl Member Since: 15 Mar 2016 Location: Warsaw Posts: 98 ![]() ![]() ![]() |
![]() So looks like with my Koni shocks I don't have to worry about extended bumpstops as they should be longer than the original shocks ![]() |
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 ![]() ![]() ![]() |
Actualy, if your shocks are longer, chances are their compressed length will also be longer, hence the need for extended bumpstops. But you should try cycle the suspension without the springs first and ser what you need.
What tyres will you fit? From 255/85r16 or 285/75r16 on extended bumpstops might be needed to avoid rub, specially on a 110 |
Yeah - the longer I think about it the more reasons I find pro extended bump stops. I think - having longer shocks, the distance from the axle to the frame is longer so standard bump stop is not able to prevent against bottoming of the longer shock out. That means the shock is exposed to damage in case of hard hit. Will buy the extended polybushes for the rear and front. Just seems the are not easy to find! At least Devon4x4 don't offer them for the Defenders after 2002 and the price in Poland is ridiculous.
Will use 285/75/16 - had Cooper Discoverer STT on my Discovery (and bought them again as I find them excellent) and just bought Discoverer STT PRO for the Defender ![]() |
2" lift installed.
![]() Click image to enlarge Happy owner ![]() ![]() Click image to enlarge ![]() Click image to enlarge The computer design is still in progress. Takes a lot of time, but I think it's worth it. Saves a lot of potential mistakes I could make without it. Few PrntScrns below. With bed up: Me standing in front of the sink and my wife sitting ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge With bed down: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() My biggest concern at the moment is where the cold water tank should be placed. The grey box above which my wife is sitting is the 75l tank. It is a good place considering we would like to go somewhere where is cold and stay for few nights in the car. This place could prevent the water from freezing (when the Webasto is on through the night the temperature inside would be above 0 degrees so there shouldn't be a problem with water freezing). Unfortunately the tank takes a lot of valuable space inside which could be used for storage of folded tables, chairs, shower, etc.. Thought of moving it outside where the air tank is on the picture or next to the frame on the left side of the car, but isolation takes space as well and the capacity would drop to around 40l.. Thought of using Webasto exhaust pipe running through the tank outside, so when the Webasto is on, the water should not freeze in the tank. But I'm not convinced to such solution. ![]() Click image to enlarge Any ideas guys? ![]() The tank that seets underneath the sink is 15l Elgena Nuctic_Therm (didn't purchased it yet but this is the plan). It has coolant connectors so the coolant is heating the water like in simple heater exchanger - it has also 12V 200A heater inside in case we need this. The water can be heated up to 85 degrees so it seems connecting it with cold water would make around 30l of warm water that could be used inside the car. ![]() |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2151 ![]() ![]() ![]() |
our 40 ltr tank sits under the vehicle on the drivers side moulded to fit along the chassis to keep ground clearance.
In all the time I have had this tank (20 yrs) I have never had it freeze. we do have the pipework insulated from the tank to the water pump at the sink .. seen here, the white box like thing below the drivers door under the wagon... ![]() Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() Last edited by wyvern on 29th Jun 2016 5:59pm. Edited 1 time in total |
Was considering this position as well. From my calculations seems like it could be even close to 60 liters.
Is it made of metal or plastic? 20yrs - long time. I assume it is for cold water? Quite surprising it never freezes! Even when the temperatures goes under 0 Celsius degrees? ![]() |
The tank is plastic and only holds cold water. We keep a 10 ltr water bottle in the cab as a secondary supply just in case.
The part of the UK where we live is not blessed with extreme cold winters and only go down to -4 or -5 once or twice a year .. , however as I said above, we have had this tank on 2 defenders in that time and have never had any problems ... It may well freeze in extreme winters but so far not, but then again we also don't have a fuel tank heater to keep the fuel from freezing so not sure if that can also be seen as a possible problem for cold weather. It would be easy to put a small heater pad on the tank to keep it warm if you are worried about freezing as I expect that you will have an auxiliary battery for the hotel service equipment (heater, lights, water pump etc ) There is a slim long line water tank that I have seen that fits behind the front seats like a bulk head that may do what you want, but we cherish the inside space to much to entertain one..... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
I don't think the fuel tank heater is really needed during "normal" winters - but still - with -20C the water would definitely freeze in my opinion. Considering Norway or Island temperatures around this time, I'm still thinking of finding a solution to heat the water tank a little, or at least keep it isolated.
I wouldn't like to fit anything behind the front seats as well. Would like to have possibility to get into the "hotel space" as you named it ![]() I think the position you are having, but with the small exhaust pipe going through the tank, would serve well. |
Body work has started.
First thing I've done is this simple improvement - little rubber between the rear door panel and the, hmm - ![]() ![]() ![]() ![]() Click image to enlarge Than roof had been removed. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Was also inspecting places under the car to see where the roll cage mounts should be fitted - some weight was dropped ![]() ![]() Click image to enlarge ![]() Click image to enlarge Checker plate was installed for the easier access to the front of the roof ![]() Click image to enlarge ![]() Click image to enlarge Than we have made a template for the front element that goes over the windscreen. All the dimensions were transferred to the computer for the final design and future laser cut. ![]() Click image to enlarge I was also tying to remove the fixings of the side panels, but noticed the screws were turning and there was no access to the head of the screw. That's how I found out the floor panel wasn't original ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Was quite surprise to find around 60 holes in the floor! No doubt the car is not waterproof ![]() I know it was probably for the water to go out from the car, but it is also a good way of getting water in so decided to get rid of all of them. ![]() Click image to enlarge ![]() Click image to enlarge |
Job done
![]() ![]() Click image to enlarge Finally some aluminium profiles have arrived ![]() Click image to enlarge and all the parts for the three elements: 1. Above the wind screen on the front ![]() Click image to enlarge 2. The part that will fill the hole in front of the roof ![]() Click image to enlarge 3. Rear panel above the rear door ![]() Click image to enlarge This is the closeup of the element that needs to be bent ![]() Click image to enlarge Couple more shots of the puzzles ![]() ![]() Click image to enlarge ![]() Click image to enlarge Fits nicely on the front ![]() Click image to enlarge and on the back as well ![]() Click image to enlarge ![]() This is the main part of the roll bar - the red tape pictures the bars that will be welded inside to make it stronger. This shape will allow to get to the "hotel" part of the car from the front seat. ![]() Click image to enlarge |
Rear panel welded.
![]() Click image to enlarge Front just to keep it together and check the fitment ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge A little "nicer" back ![]() ![]() Click image to enlarge And now the question - is such a big difference, between the door line and the rear panel, normal? ![]() Click image to enlarge Seems like there might be something wrong and the fitment with the front element can be a problem.. ![]() ![]() ![]() Click image to enlarge |
The holes in your floor - a lot of them are factory fit holes. There are supposed to be three steel rails running down the length of the floor from the back door to the bulkhead to make sliding things along a bit easier.
The gap... I seem to remember having a gap about that big when I took my roof off. The roof helps line it up and the rubber fills in the gap. I liked your weight removal technique ![]() If you've got all your plans on a computer, could you make up a kit of parts to sell? |
There was no rails in mine. I don't need them anyway, so don't bother anymore. Hope it will be more waterproof this way. Although I plan to do full bodywork when the pop top, windows and additional tanks are done I decided to do it now.
![]() Well - when I look at this picture I found somewhere on the net, it seems like this setup is more tight. ![]() Click image to enlarge Seems like there is one, continuous line from the back to the very front and the wind screen frame is as high as the back panel with windows. It's definitely not like this in mine ![]() Is this connection original? ![]() Click image to enlarge I mean those two silver brackets on the left? There was a lot of silicone there from the very beginning, but I'm not sure who made it - LR during production, or the previous user.. ![]() Click image to enlarge Will think of the parts to sell later - at this stage it is still one step forward and two steps back, so I wouldn't like to sell something that doesn't fit perfectly. And also seems like every Defender is a little bit different so not sure if this would be universal enough ![]() Will see when all is done. Main frame is being welded. Stay tuned ![]() ![]() |
