Home > Technical > 200 TDI Transfer box question
LANDROVER
Slowly working my way through my Land Rover.
Replacing bearings and propshafts...bushes all the normal things Laughing
Whilst the props are off I checked the flanges where they bolt on for excessive play etc by hand rotating them.
The front output on the Transfer box felt a little odd..... Sad It feels a little notchy as you rotate it?
I cant feel no movement up down back or forth? Just when rotated if feels like its notches as turned?
All others, rear and diff ones turn with a touch of back lash but smoothly..
When driving I cant say I noticed any excessive noise etc?
What is the normal sufferings would you say of the transfer box and should I pull the front output bearing and shaft out to inspect?
If there anything someone could have done wrong to cause this? Wrong setting of bearing or torque of bolt?
I have yet to have the pleasure of dissasembly of a transfer box so was hoping for a bit of advice/pictures of what I will encounter before I get into pieces.
Thanks everyone. Thumbs Up
Post #535077 27th May 2016 8:08am
isacs
Nothing to worry about at all. I just put my transfer box back in after having 1.211 gears put in it and an overhaul and that's exactly how it should feel (I was told)
Post #535171 27th May 2016 3:16pm
It's probably because you're turning the centre differential gears when you rotate the front flange but not when you turn the rear.
Post #535210 27th May 2016 6:19pm
LANDROVER
Interesting I will have another look. It feels a bit rough. I was a bit worried by how it felt. I will have to reassemble it and see how it drives. Might video it if I can work out how. Embarassed
Post #535218 27th May 2016 6:46pm
LANDROVER
...Not sure I was looking at the diagram last night but not really had to pull one apart yet...thankfully.
I was worried about the bearing and output shaft itself.
I will see what happens when I reassemble it and hopefully put some miles on it.
Its wearing lots of new things now so got to be better...I hope Rolling with laughter
When I finally get it together I will put some pictures up of it.
Post #535219 27th May 2016 6:51pm
