![]() | Home > Technical > 200 TDI Transfer box question |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
Nothing to worry about at all. I just put my transfer box back in after having 1.211 gears put in it and an overhaul and that's exactly how it should feel (I was told)
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
It's probably because you're turning the centre differential gears when you rotate the front flange but not when you turn the rear.
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 232 ![]() ![]() |
Interesting I will have another look. It feels a bit rough. I was a bit worried by how it felt. I will have to reassemble it and see how it drives. Might video it if I can work out how. ![]() |
...Not sure I was looking at the diagram last night but not really had to pull one apart yet...thankfully. I was worried about the bearing and output shaft itself. I will see what happens when I reassemble it and hopefully put some miles on it. Its wearing lots of new things now so got to be better...I hope ![]() When I finally get it together I will put some pictures up of it. |
