Home > Puma (Tdci) > Puma Engine Mileage
Page 4 of 10 <12345678910>
JABBBM
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Yulong White
65 plate Adventure 110
6500 miles (4000) in last 6 weeks about average
No issues in fact just getting better each time i use it Very Happy
my last 2.2 had 85K miles on before i changed it and only had the turbo hose issues 110 Adventure - Grey with lots of extras - almost the best
110 Adventure White with Bowler Stage 1 upgrade - Go anywhere and Go fast my 25th Landy but by far the best. -now gone thanks to a lorry not seeing me....
Post #533885 23rd May 2016 12:54am
Caterham
blackwolf wrote:
Seeing that this thread has miraculously come alive again after a 6 year sleep!
190,000 miles, 2007 DC 110, engine problems - 1 VCV, 1 chafed harness, 1 bolt on exhaust manifold persistently working loose. That's all I can remember anyway.
- wouldn't be the bolt cloestest to the bulkhead by any chance (ask me how I know). found a cure for it?
Post #533900 23rd May 2016 7:16am
smb
145,000 miles, 2011 110CSW used daily with regular 6-700miles/day. Has become a lot more reliable since not being serviced by dealer Thumbs Up
Post #533959 23rd May 2016 12:53pm
No, that would be too easy! It's the one at the other end, behind the massive ladder bracket that holds the alternator, serpentine belt idlers, and (if fitted) the a/c pump. As a further inconvenience, the thread in the cylinder head is now giving out, meaning that it will need a threaded insert fitted to repair. That means a ridiculous amount of dismantling just to get straight-line access to the hole in order to drill and tap it oversize. Grrr. Evil or Very Mad
At the moment I am living with the whistle, and if anyone asks it's induction noise and turbo whistle! It passed the MOT on Monday, anyway, so it can't be too obvious.
Incidentally, the correct bolts have non-removable dished washers under their heads to allow for expansion and contraction with temperature changes. I have a suspicion that many of the Puma manifold bolt problems actually result from the bolts being overtightened resulting in these dished washer becoming flattened. If you have a loose bolt, rather than simply tightening it up like a loony (the tempting approach), it is more sensible to replace it with new and torque correctly. To get a torque wrench on the front ones though you have to remove that damned bracket!
Post #534483 25th May 2016 10:16am
Caterham
very interesting - thanks BW.
can't recall seeing the bolts you're referring too?
early days my heat shield bracket was loose - ok now except one nearest bulkhead keeps coming loose.
can't you just loose the bracket and heat shield? ran mine for a year or two without the heatshield. good luck.
Post #534486 25th May 2016 10:24am
durham
England 2014 Defender 110 Puma 2.2 USW Corris Grey
A mere 20,000 here, on a 2014 USW, with about half of them to and around the heat of Southern France and Northern Spain. Its never seen a snow flake
Though to be fair I've also clocked up about 5000 in various courtesy cars ranging from a Peugeot 1litre to a 4.4 RR Sport.
Once its had its next visit to the dealers, next month, its off South again to test the aircon, get stared at and have people pose for a photo with it!!!! Its fairly standard, but at times abroad, I feel as though I'm driving a UFO as people look!
Post #534487 25th May 2016 10:31am
Ah, heat shield bracket bolts. I was describing the bolts that hold the manifold to the head.
The threaded hole in the manifold into which the bolt at the bulkhead end of the heat shield bracket screws is another trouble spot, since the thread fails. This has also happened on mine, and is a crass piece of design. I have a new take-off manifold to fit on mine when I do the threaded insert job I mention above, but I have also been trying to devise a replacement bracket that doesn't rely on a hole tapped into a cast-iron exhaust manifold, something which is always going to be troublesome.
I think that you probably could run without the heat shield fitted - it is a major source of rattles - but mine servers a useful function at MOT time because it, together with the cat heatshield which is still fitted, makes it virtually impossible to see that there isn't actually a cat fitted any more. Incidentally removing the cat lowered underbonnet temperatures (and driver's footwell temperatures) by a very noticeable amount.
Post #534506 25th May 2016 11:50am
Caterham
thanks BW.
looking to remove the CAT myself (well with some help) - thinking along the lines of smashing the internals out?
Post #534511 25th May 2016 12:14pm
Yes, a big masonry drill and some brute force and ignorance! Disembowel the cat! From the outside and with current exhaust gas analysers you can't tell it's been done! Thumbs Up
Post #534559 25th May 2016 2:17pm
Caterham
Thumbs Up
wondered Off Topic - sorry OP.
Post #534631 25th May 2016 7:23pm
MK
Re: Puma Engine Mileage
Please post :
- Mileage:85000 km
- Year make. 2007
- Body type, 110 sw
-The main use of the vehicle: 90% highway to hit the 10% off road
- Engine: no issues (oil: a blend of PAO synthetics of 5w-30 913A/B-C-D and 5w-40 as it is remapped) Puma 110" SW
Post #535627 29th May 2016 2:38pm
NickMc
I had one 2008 2.4 tdci with 285,000 miles on it, it had an engine at 42k.
Post #535763 30th May 2016 12:01am
Jonnie421
Wales 2007 Defender 90 Puma 2.4 SW Tonga Green
Mileage -,66,000
Year -- Dec2007
Model 90 CSW
Main use - A roads taking dogs out and collecting logs !!!!!
Engine running smoothly , leak problems sorted( I keep it in the garage !!! ) Defender 90 Tonga green . My 2007 County .2.4Tdci puma .
Too many other Discos to mention, including a V8 petrol Disco3 and diesel Disco 3 !! ( All gone)
Post #535785 30th May 2016 9:16am
enfield_dinosaur
2007 Defender 110 Puma 2.4 SW Java Black
Please post :
- Mileage: 67k miles
- Year make: 2007
- Body type: 110 SW
-The main use of the vehicle (city,country,farm,comp) etc: 80% onroad, 20% offroad
Also any
- Engine ONLY specific problems, Please no gearbox,diff,electrical,EGR etc problems:
Engine developed a knocking due to worn copper gaskets at 66k miles, it's fixed, albeit not sure yet if it's fixed the knock completely
Post #535788 30th May 2016 9:24am
Defender2014
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Mileage - 25,000
Year -- Sept 2014
Model - 110 SW
Main use - A roads, farm track and chasing my Cocker Spaniel, Boris, who would have run away......................again!
Engine - brake fluid reservoir cap when warning switch failed and blown turbo hose Defender Puma 110XS SW
Kawasaki ZX9R El
Suzuki RGV250M
Honda CB250N Super Dream
Post #536000 30th May 2016 10:32pm
