Home > Puma (Tdci) > Another output shaft failure...
Page 4 of 10 <12345678910>
It would be interesting to hear of any high mileage Ashcroft units - anyone done 200,000 miles on one yet? Or done a substantial mileage and then inspected it?
Post #533449 21st May 2016 5:40pm
Fish13
Scotland 2012 Defender 90 Puma 2.2 HT Tamar Blue
Back together now and it drives like a car, very smooth compared to how it was before. When I bought it, there was a lot of backlash, but I had no idea how much, compared to what it is like with new parts.
Post #533480 21st May 2016 7:42pm
YOLO110
Australia
Thats good news.
Interested in...
Did they fit OEM standard replacement parts?
Did they 'grease' the output shaft? YOLO... You Only Live Once...
Post #533527 21st May 2016 9:26pm
Fish13
Yep, oem parts and everything greased to within an inch of its life! Very Happy
Post #533544 21st May 2016 9:53pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I understand from my local Indy that since mid way through 2015 the splines have been greased with some sort of blue anti scuffing paste, time will tell if this is a robust fix.
Post #533559 21st May 2016 10:23pm
YOLO110
Australia
Mine is a June MY15...
If I wanted my JLR dealer to check if mine had been done, any idea of what is involved and how long that job would take?
Peace of mind and all that...! Thumbs Up YOLO... You Only Live Once...
Post #533599 22nd May 2016 2:53am
defender9
I believe that if you give them the VIN number they could tell you if its had this modification, certainly my Indy checked mine and he said it would have been done.
Post #533643 22nd May 2016 9:41am
YOLO110
Australia
Interesting...
Can you clarify... is this an 'official' JLR cited modification that is required to be done?
Cheers, Pete. YOLO... You Only Live Once...
Post #533662 22nd May 2016 10:57am
defender9
I don't think its a recall Pete but from what I understand the factory started applying this anti scuff paste from mid 2015 I assume due to the reported failures. I think if I had a Puma built before mid 2015 I think I would be asking the dealer if they would as a goodwill gesture carry out this mod.
Post #533702 22nd May 2016 2:51pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
There have been a couple of posts about a blue drip from the gearbox/transfer box area onto the floor so this sounds plausible. on my Jan 2016 model I had a blue stain in the same area which I just wiped off. Looks like mine has some grease on it Very Happy
Post #533748 22nd May 2016 5:37pm
ericvv
^^ Thread on this blue grease is below. Have been following those threads both on here and on aulro.com, and looks like this grease really was applied during assembly in the last 3 months only. Why it is leaking out for a while right from new never got clarified.
Eric
http://www.defender2.net/forum/topic42448....lue+grease You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #533798 22nd May 2016 8:01pm
YOLO110
Australia
I think I will do this... good idea thanks!
To save too much 'trolling'... do you happen to know what is the recommended type of grease please? It would be good to use the same blue/green stuff that late build owners have reported 'leaking' out... (that sounds to me like it is not very viscous..?)
How long does it take to get to the output shaft anyway? Question YOLO... You Only Live Once...
Post #533858 22nd May 2016 10:33pm
Alien
Australia
The owners book lists the type of grease(I don't have access to mine at the moment).
It was recommend to me to use "one shot grease" as used in the swivel housings.
It would be a full day's work to drop the transfer, inspect/grease the shaft and refit the transfer.
Add delays if parts have to be sourced.
Most shops would want it for 2 days to cover themselves.
Subject to mileage I'd consider asking about changing the O rings on the intermediate shaft and inspecting the centre diff shims. Cheers,
Kyle.
Post #533888 23rd May 2016 2:29am
YOLO110
Australia
Cheers mate. Very Happy YOLO... You Only Live Once...
Post #533929 23rd May 2016 10:40am
Devon-Rover
The number is Lr078521 for what is described as the weicon Anti scuff paste.
Post #534009 23rd May 2016 4:35pm
