Home > Puma (Tdci) > 12v feed behind R/S rear speaker panel purple +ve, black -v
Happyoldgit
Is the unused 12v feed plug behind the R/S rear speaker panel (purple +ve, black -ve) a fused supply and if so where is the fuse located?
Cheers. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #53261 16th Jan 2011 3:05pm
walfy
If it's the same as a PUMA 90 then the fuse is under the drivers seat. Once the fuse is in it then makes that connector at the rear perm live 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #53263 16th Jan 2011 3:07pm
Happyoldgit
Gotcha, I'll go and have a look. Mine is live all the time so looks as though the fuse is already in.
Thanks for that Thumbs Up Steve.
Post #53264 16th Jan 2011 3:17pm
Happyoldgit
Found it.
Thanks again. Steve.
Post #53267 16th Jan 2011 3:34pm
jst
so was mine. i think on the older vehicles 07/08 the fuse needed to be added. 09 onwards they seem to already have it fitted. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #53268 16th Jan 2011 3:36pm
mse
early 08 Fuse was in
Ive not come across one even an 07 without a fuse...although it could be a model thing (it was an XS as is mine) Mike
Post #53303 16th Jan 2011 5:37pm
walfy
Mine was a 57 90 XS. That didn't have the fuse fitted.
But it did have a leak that LR couldn't fix 110 D250 SE HT
110 USW SOLD
Post #53306 16th Jan 2011 5:42pm
mse
There's always one! Mike
Post #53307 16th Jan 2011 5:43pm
walfy
I'm sure others have leaks Rolling with laughter 110 D250 SE HT
110 USW SOLD
Post #53308 16th Jan 2011 5:45pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
What do you guys wana do with this 12 V supply? What is the fuse rated at? Dont wana burn the wire before the fuse fails. Would be great to get a 12 V supply that's already wired up!
Post #53320 16th Jan 2011 6:24pm
walfy
I fitted a cigarette style receiver in the speaker panel. I then used this for running my coolbox and I had some exterior lights on an extension lead. 110 D250 SE HT
110 USW SOLD
Post #53322 16th Jan 2011 6:30pm
Marius
One should be carefull. I've heard of people melting wires pulling 4 amps on fridges where the wires just isn't thick enough. I'm planning a DIY dual battery system. I installed one before in a cruiser. Taking 16mm^2 wires to the back to run my fridge (pulling bour 40 wat max), and everything else. That extra 12V for running small stuff though will be sweet!
Post #53328 16th Jan 2011 6:38pm
walfy
Coolbox not fridge.
On my D3 I ran some big cables to the rear to an aux fuse box to run the fridge. 110 D250 SE HT
110 USW SOLD
Post #53332 16th Jan 2011 6:57pm
jst
i have run a fridge off mine, no problems to date.
TJ101s 07 didn't have a fuse fitted. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #53341 16th Jan 2011 7:22pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
My 57 is fused already.
It's a good supply for a rear work light. I assumed it was intended for that although a lot of people add aux sockets. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #53647 18th Jan 2011 2:52pm
