![]() | Home > Puma (Tdci) > 12v feed behind R/S rear speaker panel purple +ve, black -v |
Is the unused 12v feed plug behind the R/S rear speaker panel (purple +ve, black -ve) a fused supply and if so where is the fuse located?
Cheers. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Gotcha, I'll go and have a look. Mine is live all the time so looks as though the fuse is already in.
Thanks for that ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Found it.
Thanks again. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8337 ![]() ![]() ![]() |
so was mine. i think on the older vehicles 07/08 the fuse needed to be added. 09 onwards they seem to already have it fitted. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
early 08 Fuse was in
Ive not come across one even an 07 without a fuse...although it could be a model thing (it was an XS as is mine) Mike |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
Mine was a 57 90 XS. That didn't have the fuse fitted.
But it did have a leak that LR couldn't fix 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
There's always one! Mike |
I'm sure others have leaks
![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
What do you guys wana do with this 12 V supply? What is the fuse rated at? Dont wana burn the wire before the fuse fails. Would be great to get a 12 V supply that's already wired up!
I fitted a cigarette style receiver in the speaker panel. I then used this for running my coolbox and I had some exterior lights on an extension lead. 110 D250 SE HT
One should be carefull. I've heard of people melting wires pulling 4 amps on fridges where the wires just isn't thick enough. I'm planning a DIY dual battery system. I installed one before in a cruiser. Taking 16mm^2 wires to the back to run my fridge (pulling bour 40 wat max), and everything else. That extra 12V for running small stuff though will be sweet!
Coolbox not fridge.
On my D3 I ran some big cables to the rear to an aux fuse box to run the fridge. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
i have run a fridge off mine, no problems to date.
TJ101s 07 didn't have a fuse fitted. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
My 57 is fused already.
It's a good supply for a rear work light. I assumed it was intended for that although a lot of people add aux sockets. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
