![]() | Home > Maintenance & Modifications > Wheel bearings or something else |
Tia4 Member Since: 15 May 2012 Location: Surrey Posts: 48 ![]() ![]() ![]() |
Had my 300tdi up on the jack today to check to see if my front brakes were sticking as have had very hot pads, before removing wheel noticed I had a lot of play if I rocked the tyre 12 to 6 but not much 9 to 3. After removing wheel I had a slight rubbing noise in one place. So my questions are am I looking at my wheel bearing need replacing then replace my pads and discs? Is this something a novice can attempt any tips/ hint appreciated.
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
I had the same. Spent the day yesterday fitting new top and bottom bearings (plus gaskets and seals etc.). Reasonably easy job, takes a while and is quite possibly the dirtiest job I've ever done!
However, I now have near perfect steering (95%) and no wandering defender ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
I need to do one of my swivel seals at some point
It's one of those jobs. Not particularly technical or difficult. But long, laborious and filthy. But once done, makes a world of difference
I made the mistake of not having swivels balls to hand to swap out. So it means I have to do it again at some point. Twice. Or just keep filling with one shot ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8372 ![]() ![]() ![]() |
what he said Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
