Home > Off Topic > Pc cable support please
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Hi all, I'm in the process of getting a new to me Dell optiplex 760 which is as I understand equipped with a displayport, I am wanting to use my tv as the monitor so need a dp to hdmi which are readily available however I only have 2 hdmi ports on the TV one is virgin one is blue ray so I would need a splitter which are also available. Question is can i get one cable that is both ie hdmi male and dp + hdmi female, so I have less joints and better signal? Budget and schedule are both tight as I would like to be up and running by Monday so a high street supplier I can visit would be great. All help appreciated. Rhubarb and custard let fly with their secret weapon.
Post #531172 13th May 2016 6:24am
Rosso_NI
United Kingdom 1993 Defender 110 2.5 n/a Diesel ST Galway Green
Lambert I think Maplin may be worth a try, they have HDMI splitters etc listed online so may have what you are looking for on the high street.
Good luck Thumbs Up 1993 Defender 110 Ex Military soft top, with a long wishlist already
Post #531193 13th May 2016 8:15am
MartinK
Or maybe another way of using the other ports on the TV?
I recently bought a DAC so I could use the optical out connector to wire to my sound system...works a treat.
USB connections for hard drive, HDMI for DVD, Optical for Sound etc.
Just wondering if you could re-use one of your existing devices (Blue Ray) and connect it in a different way (optical, USB?) to free-up the hdmi, so you can use that for your Dell PC.
BTW after a lot of research, I bought a British DAC... a "Beresford"... http://www.homehifi.co.uk/S/home.htm
Fibre optic cables are cheap as chips Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #531208 13th May 2016 9:35am
lambert.the.farmer
Yeah I have been trawling their pages and whilst I have found various options I don't see what I ideally want but that is probably because I don't know if it has a special name. One of the occasions when not being truly computer literate is biting me in the bum. Rhubarb and custard let fly with their secret weapon.
Post #531210 13th May 2016 9:40am
MartinK
You will probably be able to download the technical manual for your TV off t'internet...
Then check if there's another combo of options to connect your Blue Ray... freeing the HDMI for your PC...
You can often get small converters (from Maplins or online maybe like Amazon)
Just a thought/example...
https://www.amazon.co.uk/Optical-Toslink-C...B00SIZEPOQ
Dependant if you have a smart tv you may also be able to connect your PC via blue tooth or wireless network? (I think I can with my Panasonic...but never tried it). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #531248 13th May 2016 12:25pm
lambert.the.farmer
The only unused ports on the TV are 1 usb2, yprpb and a network cable and unfortunately I went for 3d not smart so no wireless connectivity or bluetooth. I will fish out the manual and see if I am missing something obvious, I suspect that I am. Cheers. Rhubarb and custard let fly with their secret weapon.
Post #531271 13th May 2016 2:33pm
7heaven
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
I think you'll struggle to find a solution that doesn't require an extenral HDMI switcher (or a new TV Whistle )
The yprpb connection is 'Component' which is an HD capable connection. If your BluRay player has component output (most don't!), then you could use this to connect and free up an HDMI port for the PC. However, in general component connections don't support HDCP (HD Copy Protection) which is present on pretty much every Bluray disc.
The optical connector mentioned earlier in the thread is for audio only so no use for video. 2020 110 D200 Base - Pangea with satin paint protection
2015 90 XS Station Wagon (sold)
2010 110 XS Station Wagon (stolen)
Post #531277 13th May 2016 3:13pm
lambert.the.farmer
Ok so the new to me machine has arrived and it's not a 760 but a 745 which seems to mean just a vga output so after a session down at maplins I now have a usb to hdmi box which was set up in store, only when I get it home my Samsung tv doesn't see a signal? The machine is definitely working on my old vga monitor and the feed is set to mirror through both the vga and usb/hdmi? The only other thing is evidently the internal coin battery is on its way out so booting up needs a f1 key press which needs in turn a wired keyboard because it seems not to recognise the wireless one as it calls itself something other than a keyboard, but only in the boot sequence. is all this related and could a new battery obviate the issue of it not feeding the usb/hdmi? Can you tell I'm at the limit of my understanding of computers? Any help would be appreciated. Rhubarb and custard let fly with their secret weapon.
Post #531417 14th May 2016 6:06am
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Some of the older TV's don't support full HD although they have HDMI ports,so the resolution that your new PC is trying to use the TV can't display.
If you use the old VGA screen try and set the resolution to a fixed size and then swapbto the TV and see what gets displayed.
Post #531462 14th May 2016 11:10am
lambert.the.farmer
cheers for all the input guys. it seems that the main issue stems from the bios now looking for a non existent drive and needing the f1 key pressing to bypass which until it is pressed the machine doesn't accept the usb/hdmi as a device. once up and running all is fine. pita. Rhubarb and custard let fly with their secret weapon.
Post #531501 14th May 2016 3:30pm
