Page 905 of 1392 <123 ... 904905906 ... 139013911392>
ericvv
Post #529365 5th May 2016 5:14pm
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Finished fitting/plumbing this bad boy. Muchos wind and 2x air locking diff feeds ready for the next stage.
Post #529370 5th May 2016 5:43pm
excossack
Fitted the rear MudStuff speaker mounts ready for a set of 130mm speakers - when I buy a set.
Started adding some foam insulation around the rear windows and also added some behind the speaker pods.
Need some contact adhesive next to stick the foam to the metal work.
Got the winch back from Goodwinch after a service. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #529577 6th May 2016 5:49pm
Just drove it after lots of new parts fitted, everything seating in now.
More than enough work has been done on it lately!
Post #529579 6th May 2016 6:05pm
srod
Clocked 100k!
('53 TD5)
Post #529799 7th May 2016 8:12pm
AndyS
Fitted one of them dog guard thingies that goes between the 'boot' and the back of the seats to keep pooch safe.
What a palava, all caused by the totally crap instructions which were all in picture form without any words at all. It took me about three hours (gauged by the radio turning itself off twice) which is about two hours longer than it would have taken if they put words in the instructions.
Anyway, it's done. Next task is to build a box to level out the wheel arches and create a space to hide all the crap I lug around for no reason.
Post #529803 7th May 2016 8:25pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Pumped it up
Post #529816 7th May 2016 9:08pm
Huttopia
I used the old one to chase two cars of yoofs off the farm. Its funny how a slightly careworn pick up says 'don't argue'! Tomorrow I will mostly be spraying ACF-50 on the Heritage as per the corrosion prevention sticky, hopefully without interruptions...
Post #529823 7th May 2016 9:16pm
keith
Finally got the LWT back on the road after winter refurb and new cylinder head . MOT'd and running sweet .
Post #529824 7th May 2016 9:20pm
YOLO110
Australia
chopcat wrote:
Pumped it up
Is that HF? YOLO... You Only Live Once...
Post #529825 7th May 2016 9:20pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Went from this
To this.
 2002 td5 90 county hardtop
Post #529833 7th May 2016 9:55pm
Stacey007
^ interested to see the final finish,
Fed up of mine looking a mess, what products did you use.
Thanks
Post #529835 7th May 2016 10:05pm
jaygti
I sanded it all over, then I treated the rust with Bilt Hamber hydrate 80.
What you see at the end is just 2 coats of halfords primer.
It takes 24 hrs to dry properly, so I will spray it black tomorrow.
I've got Matt black, but I'm not sure wether to spray it satin black instead.
When it's all finished I'm going to spray some Bilt Hamber dynax-UC over it. It's a thin clear film that's supposed to protect the paint and metal.
It's worth a try anyway! Smile 2002 td5 90 county hardtop
Post #529842 7th May 2016 10:29pm
jaygti wrote:
Went from this
To this.
[img:672:650]https://www.defender2.net/gallery/albums/userpics/13906/normal_image~1.jpeg[/iimg]
Someone's stolen the bottom of your towbar! Shocked
Post #529844 7th May 2016 10:38pm
jaygti
It kept dragging on the ground when it took the defender off road. So I took it into work and cut it off. The tow ball still goes low enough when I use it occasionally. Thumbs Up 2002 td5 90 county hardtop
Post #529849 7th May 2016 10:45pm
