Home > Technical > LT85 transmission tunnel
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
I've read on another forum that the hole for the gearstick in a lt85 transmission tunnel is an inch and a half closer to the bulkhead than on an R380 gearbox. The lt85 tunnel supposedly should fit in place of the R380 one. Can anyone confirm this? If it's the case it would explain why my v8 air filter will not fit between the engine and bulkhead. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #529309 5th May 2016 2:01pm
Romadog
You should only have a change re the air filter if the engine has moved on its mounts. Seems odd as these are not adjustable and neither is the bulkhead position.
Post #529316 5th May 2016 2:13pm
charcoal
The engine has been retrofitted, it was originally a 300tdi. The gearbox is on the original R380 mounts and the engine mounts where moved to suit. 1999 Land Rover Defender 110 td5 station wagon
Post #529324 5th May 2016 2:30pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
The bell housing is different for V8 engines... V8 90...WIP
Post #529331 5th May 2016 2:46pm
charcoal
I know, I have an lt85 with v8 inside my vehicle working. Not what I'm asking, I just want to find out if the hole in the transmission tunnel is in a different place on the lt85 transmission tunnel. 1999 Land Rover Defender 110 td5 station wagon
Post #529332 5th May 2016 3:03pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
I have a LT85 tunnel / floors in the shed if you were intreasted? Working towards Carry on camping!
Post #529360 5th May 2016 4:51pm
charcoal
PM sent Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #529361 5th May 2016 4:55pm
