![]() | Home > Td5 > Any body know what this box is fitted under drivers seat |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Some sort of security thing I'd say - only two wires and the OE one is green and black, which is the fuel pump.
It's either a tracker or an aftermarket "tuning" box that effectively just over fuels the engine. How is it connected? Is it soldiered or just crimped in? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
Thanks for the reply it has 3 wires the black is the earth the brown conects to the loom wire a yellow and white the other is a green and goes into the ecu, I have cut the wires and it still starts and runs ok.
Has a toad alarm fitted and also had a Jeremy fern tuning big into caller etc. I purchased this with the mods done box has no markings at all. looking at upgrading the loom to better spec. Will post some pics of where wires from |
Just taken a few pictures of where wires went
![]() Click image to enlarge ![]() Click image to enlarge Cheers Ash |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
It is a boost box not a 'tuning box'. Have a look at BAS or alive for info
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Hi Steve thanks for clearing that up for me
![]() Cheers Ash |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge engine ECU wire diagram TD5 |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
As above, look like a boost box.
Essentially, stops the ECU going into limp mode when it hits about 18psi and detects over boost (after twiddling waste gate rod for example). The most overpriced bits of kit i've seen. I bought the hardware to build 10 of these boxes for about £15. The britpart version of this is about £100 - crazy! It's a zener-diode, a tiny bit of cable, an aluminium box and a shedload of silicone or other compound to a) make waterproof and b) make it heavier so you think you're getting more for your money! To the OP, it might mean your actuator has been fiddled with (or something more substantial). Check your waste gate actuator rod, there should be about 12ish threads showing as standard. I think I remember reading you can crank it to about 9 threads on a standard engine (no remap etc) |
