Home > Td5 > Any body know what this box is fitted under drivers seat
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Just wondered if any body can shed any light has to what this extra box is or does?
Many thanks Ash
Post #528018 30th Apr 2016 10:37am
Anderzander
Some sort of security thing I'd say - only two wires and the OE one is green and black, which is the fuel pump.
Post #528021 30th Apr 2016 10:56am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
It's either a tracker or an aftermarket "tuning" box that effectively just over fuels the engine. How is it connected? Is it soldiered or just crimped in? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #528022 30th Apr 2016 10:57am
Landyash
Thanks for the reply it has 3 wires the black is the earth the brown conects to the loom wire a yellow and white the other is a green and goes into the ecu, I have cut the wires and it still starts and runs ok.
Has a toad alarm fitted and also had a Jeremy fern tuning big into caller etc.
I purchased this with the mods done box has no markings at all.
looking at upgrading the loom to better spec.
Will post some pics of where wires from
Post #528034 30th Apr 2016 11:34am
Landyash
Just taken a few pictures of where wires went
Cheers Ash
Post #528035 30th Apr 2016 11:37am
rallysteve
It is a boost box not a 'tuning box'. Have a look at BAS or alive for info
Post #528039 30th Apr 2016 12:15pm
Landyash
Hi Steve thanks for clearing that up for me Thumbs Up
Cheers Ash
Post #528056 30th Apr 2016 1:26pm
dorsetsmith
engine ECU wire diagram TD5
Post #528074 30th Apr 2016 2:46pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
As above, look like a boost box.
Essentially, stops the ECU going into limp mode when it hits about 18psi and detects over boost (after twiddling waste gate rod for example). The most overpriced bits of kit i've seen. I bought the hardware to build 10 of these boxes for about �15. The britpart version of this is about �100 - crazy!
It's a zener-diode, a tiny bit of cable, an aluminium box and a shedload of silicone or other compound to a) make waterproof and b) make it heavier so you think you're getting more for your money!
To the OP, it might mean your actuator has been fiddled with (or something more substantial). Check your waste gate actuator rod, there should be about 12ish threads showing as standard. I think I remember reading you can crank it to about 9 threads on a standard engine (no remap etc)
Post #529294 5th May 2016 12:23pm
