Home > Maintenance & Modifications > Waterpump
Page 2 of 2 <12
There is a slight bit of corrosion on one of the mating faces of the Waterpump.
I think it's the pump to vac pump above, so not the leak area.
How could I remove that, very light very fine wet and dry say 2000 grit kept flat?
Post #515384 17th Mar 2016 7:10pm
Last update on here, fitted the original pump.
New fixings and genuine gasket and done all the bleeding and so on....
New pump will go back for refund.
Most important thing....
No leaks no drips! Problem cured it was the gasket!
So a nearly �600 bill for a pump I didn't need all for a �10 gasket which was all that was wrong. Rolling Eyes
And it wasn't cracked....
Very pleased as you can imagine.
Post #516541 21st Mar 2016 8:42pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
It's amazing how many garages are willing to pull your trousers down and give you a right royal shafting!!! Evil or Very Mad Evil or Very Mad 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #516548 21st Mar 2016 8:50pm
Very true, a main dealer as well. Evil or Very Mad
Post #516551 21st Mar 2016 8:55pm
williamthedog
That's why it's better to do your own maintenance if you can.
You can see for yourself the problem then.And nobody tries to con you Thumbs Up
Post #516553 21st Mar 2016 9:00pm
Very true, I don't regret the test though as extra confirmation of where exactly it was leaking from.
But I knew fairly well myself anyway...
You'd expect better from a large main dealer.
Post #516555 21st Mar 2016 9:02pm
Well just an update on this mainly for others benefit.
I went for a Borg and Beck Waterpump in the end, and has been perfect, massive price difference between it and Genuine and its identical.
Regardless of this I had an opportunity today to take a photo of the bolts for others reference.
Post #529132 4th May 2016 8:12pm
Page 2 of 2 <12
