![]() | Home > Maintenance & Modifications > Waterpump |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20861 ![]() ![]() |
Last update on here, fitted the original pump.
New fixings and genuine gasket and done all the bleeding and so on.... New pump will go back for refund. Most important thing.... No leaks no drips! Problem cured it was the gasket! So a nearly £600 bill for a pump I didn't need all for a £10 gasket which was all that was wrong. ![]() And it wasn't cracked.... Very pleased as you can imagine. |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
It's amazing how many garages are willing to pull your trousers down and give you a right royal shafting!!!
![]() ![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Very true, a main dealer as well.
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
That's why it's better to do your own maintenance if you can.
You can see for yourself the problem then.And nobody tries to con you ![]() |
Very true, I don't regret the test though as extra confirmation of where exactly it was leaking from.
But I knew fairly well myself anyway... You'd expect better from a large main dealer. |
Well just an update on this mainly for others benefit.
I went for a Borg and Beck Waterpump in the end, and has been perfect, massive price difference between it and Genuine and its identical. Regardless of this I had an opportunity today to take a photo of the bolts for others reference. ![]() Click image to enlarge ![]() Click image to enlarge |
