Home > Tdi > Clutch pedal sticking down |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Long shot but if you look form under the bonnet. You will find a nut on the clutch box housing undo it and pump some grease into it. Is a long shot but will not cost much. Best of luck.
Click image to enlarge Not the best picture it's just to the right where throttle cable drops down! |
26th Apr 2016 9:50pm |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 |
Thanks Steve will have a look when I'm at "work"
Simon |
27th Apr 2016 7:22am |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 570 |
You could also try lubing the adjuster pivot under the master cylinder cover plate.First,
I have just changed my master & slave cylinder for the same problem. Marc |
27th Apr 2016 4:55pm |
Quick update swopped the master and clutch cylinders problem sorted. Anyone having a go at this and using the Haynes manual,the book says remove the clutch pedal rubber to ease pedal box removal (don't bother waste of time) better to remove the air cleaner box as pulling the pedal box assembly through the bulkhead and turning it though 90 degrees is a bit tricky as it fouls the air box and brake servo. Also when replacing slave cylinder make sure you put the bleed screw above the fluid feed pipe this eases bleeding
3rd May 2016 10:50am |
Glad your sorted
3rd May 2016 11:02am |
