![]() | Home > For Sale & Wanted > [SOLD] Immaculate XS half Leather Seats.Full Set |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1264 ![]() ![]() |
Front and second row seat set from 2015 USW
Half Leather as per XS Trim Black with white stitching Fronts are heated, were in car for 900 miles and were always covered. They are still on the LR runners so four bolts and in. Complete with Head Rests Rears have barely been sat on and always covered too. Rear is a 60/40 split including middle seat belt and full mounting kit. Also with Head Rests A very easy swop over..or if upgrading will need two outer seat belts for rears and securing bolts. All seat faces are immaculate and unmarked. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge £1275 Collection or local delivery. price comparisons here.. http://www.ebay.co.uk/itm/281996595209?_tr...EBIDX%3AIT http://www.ebay.co.uk/itm/GENUINE-LAND-ROV...SwMTZWRI7S Clemmo ![]() Last edited by Clemmo on 5th May 2016 7:38pm. Edited 2 times in total |
Saturday bump
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
Should be a straight swap familymad I think the 130 had a different rear bulkhead but mounting of the seats to the floor will be the same
![]() Ash |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Brackets on the bottom of the rear 60/40 seats is different on the 130 from the 110. It is possible to change them though. it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3496 ![]() ![]() ![]() |
Going to view a nearly new one tomorrow with vinyl seats...... 1951 80" S1 2.0
yuk..vinyl seats...
would have to change 'em eh? would need a really fantastic set?.. ![]() ![]() ![]() ![]() Clemmo |
Hi Clemmo, you have a PM on the seats. it's a Landrover thing...
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
130 and 110 DC have slightly different rear seats to SW second row:- - as noted above the brackets securing them to the floor are different. The DC brackets will fit the SW seats though, so a swap is possible. - the DC as supplied has (totally pointless) brackets securing the top of the backrests to the rear bulkhead. The only good thing about these is that they stop the seats from rattling, but they also stops the eats from tipping to allow access to the useful storage area behind and below them. There is no detrimental effect to removing these brackets and many positive benefits to doing so, but you will find that the covers of the backrest have been cut to allow the brackets to be fitted. If fitting ex-SW seats I certainly would not fit the brackets. Unless removed, these brackets also prevent the fitment of most seat covers, by the way. - the angle the backrest makes to the seat base is different on the DC to the SW seats, and I believe that this is achieved by fitting a bush (to the DC-type seat) around the locating pin in the backrest release mechanism. Somewhere on this forum there is a thread describing the removal of this bush, but I cannot immediately find it. This does however mean that the SW seats will not fit the DC unless the modification is applied to them first since the backrest will be prevented by the back of the cab from going back far enough to lock in place. As far as I know, it is quite possible to take the bushes off the seats you're taking out and fit them to the seats you're putting in. So the seats will fit and are essentially the same, but it is not a totally straightforward swap. |
Good gen thanks. If this 130 comes off then I will be sniffing around for these
![]() 1995 110 300TDI 1995 90 300TDI |
Ebay now...
http://www.ebay.co.uk/itm/252377393625?ssP...1555.l2649 Clemmo ![]() |
SOLD
CLEMMO ![]() |
