Home > For Sale & Wanted > [SOLD] Immaculate XS half Leather Seats.Full Set
Clemmo
Front and second row seat set from 2015 USW
Half Leather as per XS Trim
Black with white stitching
Fronts are heated, were in car for 900 miles and were always covered.
They are still on the LR runners so four bolts and in.
Complete with Head Rests
Rears have barely been sat on and always covered too.
Rear is a 60/40 split including middle seat belt and full mounting kit.
Also with Head Rests
A very easy swop over..or if upgrading will need two outer seat belts for rears and securing bolts.
All seat faces are immaculate and unmarked.
£1275
Collection or local delivery.
price comparisons here..
http://www.ebay.co.uk/itm/281996595209?_tr...EBIDX%3AIT
http://www.ebay.co.uk/itm/GENUINE-LAND-ROV...SwMTZWRI7S
Clemmo Thumbs Up
Post #527882 29th Apr 2016 7:15pm
Clemmo
Saturday bump
Post #528143 30th Apr 2016 6:52pm
familymad
Any one know if these seats fit straight into a 130 TDCI replacing the vinyl ones?
Thanks 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #528246 1st May 2016 8:53am
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Should be a straight swap familymad I think the 130 had a different rear bulkhead but mounting of the seats to the floor will be the same Thumbs Up
Ash
Post #528260 1st May 2016 9:51am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Brackets on the bottom of the rear 60/40 seats is different on the 130 from the 110. It is possible to change them though. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #528608 2nd May 2016 8:09pm
familymad
Going to view a nearly new one tomorrow with vinyl seats...... 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #528644 2nd May 2016 9:19pm
Clemmo
yuk..vinyl seats...
would have to change 'em eh?
would need a really fantastic set?.. Whistle Whistle Whistle Whistle
Clemmo
Post #528666 2nd May 2016 10:29pm
CDN38
Hi Clemmo, you have a PM on the seats. it's a Landrover thing...
Post #528699 3rd May 2016 2:40am
Thanks
130 and 110 DC have slightly different rear seats to SW second row:-
- as noted above the brackets securing them to the floor are different. The DC brackets will fit the SW seats though, so a swap is possible.
- the DC as supplied has (totally pointless) brackets securing the top of the backrests to the rear bulkhead. The only good thing about these is that they stop the seats from rattling, but they also stops the eats from tipping to allow access to the useful storage area behind and below them. There is no detrimental effect to removing these brackets and many positive benefits to doing so, but you will find that the covers of the backrest have been cut to allow the brackets to be fitted. If fitting ex-SW seats I certainly would not fit the brackets. Unless removed, these brackets also prevent the fitment of most seat covers, by the way.
- the angle the backrest makes to the seat base is different on the DC to the SW seats, and I believe that this is achieved by fitting a bush (to the DC-type seat) around the locating pin in the backrest release mechanism. Somewhere on this forum there is a thread describing the removal of this bush, but I cannot immediately find it. This does however mean that the SW seats will not fit the DC unless the modification is applied to them first since the backrest will be prevented by the back of the cab from going back far enough to lock in place. As far as I know, it is quite possible to take the bushes off the seats you're taking out and fit them to the seats you're putting in.
So the seats will fit and are essentially the same, but it is not a totally straightforward swap.
Post #528723 3rd May 2016 9:19am
familymad
Good gen thanks. If this 130 comes off then I will be sniffing around for these Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #528736 3rd May 2016 10:49am
Clemmo
Post #528999 4th May 2016 10:21am
Clemmo
SOLD
CLEMMO Thumbs Up
Post #529396 5th May 2016 7:38pm
