![]() | Home > Technical > Nanocom Evolution |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Don't you just love it telling you the fault code and then what the fault is, so no more looking up fault codes
How did you get on ![]() |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
can now get access to engine & map but not AS10 & wabco
will play around with codes until I get all 4 2001 TD5 110 DCPU in Bonatti Grey |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
I cannot access as10 either? Not bothered at the moment but just let you know your not the only one.
Steve p.s I bought my Landrover 2nd hand and was told the transfer was a Discovery but I always though it seemed high revving. Now I have my nanocom the Revs are 2150rpm @ 60mph on 7.50 x 16 tyres. Does anyone know what they have? |
BBS SPY Site Sponsor Member Since: 26 Dec 2010 Location: Limassol Posts: 45 ![]() ![]() |
Errm actually it is 10AS ![]() Quite a system with a lot of settings possibilities. http://www.blackbox-solutions.com/shop/help/SM031.html It's a successor to the identically looking but black Lucas 5AS which is fitted in just about every Rover car, but is not so advanced. http://www.blackbox-solutions.com/shop/help/SM034.html There is also a Lucas 2AS which was fitted to the MG RV8, but that has no diagnostic capability at all. |
![]() Click image to enlarge I too called it the AS10 module, think the prefix was lost in translation from Italian to English ![]() ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
All systems working on mine - 10AS, Instrument etc...probably your code thing.
Fantastic system on all the bits ive tried. Mike |
mse, yep it sure is a great system
![]() Yea, i noticed the AS10 Typo on the unit too Brian, and figured it was a translation error. I saw others such as Spped. As the NANOCOM's diagnostic functionality was mainly derived from our own software, hence the reason it is a great system, in a lot of cases, Nanocom owners can reference our equipments help pages. to do this, go to our web shop, select MSV-2 on the left, then select software and multi vehicle in the middle, and scroll down to the requisite vehicle system. Then click on the more info button by the side of it to give you the help page. If anyone notes any more typos, drop me a PM and i will fix them myself or get them fixed for the next firmware upgrade release. ![]() |
Hi,
So looking more into my nanocom I found this picture on the internet which someone has taken ( and I borrowed ) I tried to search for this 'graphic viewer software' but cannot find it. Has anyone else done this and what software did they use? Steve ![]() |
You get it from HERE
doh... thanks Lorryman. Looking at all the downloads, where do you start? Do they all need adding or just the most recent ones? Steve |
Are you referring to the firmware upgrades ![]() ![]() ![]() |
Hi,
Yes the Firmware ( I think), I downloaded the guides ( shall print and read later ) and now have the viewer thanks. there is the ; TD5 INSTRUMENT application upgrade NANOCOM EVOLUTION UPGRADE PACK 21/10/2010 NANOCOM EVOLUTION application - operating system upgrade pack NANOCOM software for PC 2.05 Nanocom USB Driver installation files sorry for questions, I actually find it quite confusing ![]() Steve |
Steve,
your nanocom will have all these updates installed already ![]() ![]() |
