![]() | Home > Technical > Nanocom Evolution |
OK the license code 1 is the unlock for box no1. Replace the code in that box with the new license code. Then license 2 for box 2, license 3 for box 3 I'm sure you get the idea. Now when you have inserted the new codes you must cycle through all the license screens on your nanocom until you get to the last page where you have to save the changes made, otherwise the codes revert back to the original and you will need to start again.
HTH |
Blindpugh Member Since: 14 Jun 2010 Location: Reading Posts: 40 ![]() ![]() ![]() |
Just got mine today but your doing better than me I too plugged it in the TD5 got the unit ID code then when I go to the register your product page fill in the info and click the submit button all I get is webpage not avaliable message.
Ant ideas? He who dies with the most toys wins. |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Ahhh, you have yours!!
and you further from Germany then me ![]() |
When you go to register your unit just fill in the unit id and your email address. They are having server issues.
Thanks for that just did it with code and email and it went through now to enter the codes and save them wish me luck I'am going in. He who dies with the most toys wins.
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Right, done all that - thanks lorryman!
But now still get function locked when going to Engine or map sections - can get in to ABS & alarm ok. With the website being primarily for the original nanocom, not exactly helpful 2001 TD5 110 DCPU in Bonatti Grey |
Probably my fault as after rereading my first reply I realise I could have explained it better.
License1 = unlock box No1 License4 = unlock box No4 License7 = unlock box No7 If you have done the above, recheck the codes you have entered into the nanocom as you may have entered a wrong digit somewhere ![]() |
Sounds like a plan - just as well I saved the pre-entered codes
I'll give it a try this afternoon, and advise Cheers 2001 TD5 110 DCPU in Bonatti Grey |
Doesn't matter if you saved the pre -entered codes as the unit is looking for the correct code for the module before it can be unlocked. Just enter the license codes into the corresponding box and forget about re entering the pre entered codes in the other boxes as they are locked to you anyway as you have not purchased the unlock code for them. ![]() |
Thanks lorryman I'am in just need to find out where to find the live data revs temp airflow etc. He who dies with the most toys wins.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Got mine
Comprehensive instructions included...but my german is beyond poor (i did learn german once). I assume its out to the car, get the ID, register it online, get the software download or licence and apply to device? Mike |
It's just that easy ![]() |
I'm off to work in a minute so thought I would post what I did to get my unit up and running.
1. Took unit to car and plugged in, On main screen, pressing the bottom nanocom option gives access to the units ID. 2. On to the nanocom website and registered my units I.D. Tip, Mattia is having server problems so just enter the units ID and your email address. 3. Nanocom email you your login and password details to allow you access to the restricted section. On entering the restricted section you are given access to your units licenses. Note them down and take unit back out to car. 4. Plug unit in and go to nanocom tab and select the licenses tab. Enter the codes carefully following this guide: License1 = unlock box No1 License4 = unlock box No4 License7 = unlock box No7 The amount of licenses you need to enter depends on the version purchased. 5. Once all the licenses have been entered scroll through all the license pages until the last page and save the changes made. Otherwise you have to start again. 6. Unplug nanocom and then re plug in and voil� your nanocom is ready to go. ![]() HTH |
Aslong as you remember to save it!!
It is that simple...rather worried on the number of faults logged!!!!!!!!!!!...!!!!!!! Mike |
