Home > Technical > Nanocom Evolution
Page 1 of 3 123>
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Nanocom Evolution
Just got my unit through the group purchase.
Unpacked, plugged into my TD5 , got the unit ID, registered on the Nanocom website, gone to the restricted area to get the unlock codes, and find instead 3 License codes.
On the Nanocom itself, it already lists Unlock codes 1 to 4 (i.e. these boxes already have codes inserted).
I know that this is probably a dumb set of questions but....
Do the license codes mean the same as the unlock codes, and should I insert the 3 license codes into Unlock code boxes 1,2 & 3?
Or, do the license codes go in the first empty unlock codes boxes (5, 6 & 7).
OR, are license codes are unlock codes completely different, and if so, where do I get my unlock codes from? 2001 TD5 110 DCPU in Bonatti Grey
Post #52336 11th Jan 2011 12:19pm
Lorryman100
OK the license code 1 is the unlock for box no1. Replace the code in that box with the new license code. Then license 2 for box 2, license 3 for box 3 I'm sure you get the idea. Now when you have inserted the new codes you must cycle through all the license screens on your nanocom until you get to the last page where you have to save the changes made, otherwise the codes revert back to the original and you will need to start again.
HTH
Post #52343 11th Jan 2011 12:31pm
Blindpugh
United Kingdom 2000 Defender 130 Td5 HCPU Cairns Blue
Just got mine today but your doing better than me I too plugged it in the TD5 got the unit ID code then when I go to the register your product page fill in the info and click the submit button all I get is webpage not avaliable message.
Ant ideas? He who dies with the most toys wins.
Post #52344 11th Jan 2011 12:31pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Ahhh, you have yours!!
and you further from Germany then me Sad
Post #52346 11th Jan 2011 12:32pm
Lorryman100
When you go to register your unit just fill in the unit id and your email address. They are having server issues.
Post #52347 11th Jan 2011 12:33pm
Blindpugh
Thanks for that just did it with code and email and it went through now to enter the codes and save them wish me luck I'am going in. He who dies with the most toys wins.
Post #52349 11th Jan 2011 12:42pm
daviec1
Right, done all that - thanks lorryman!
But now still get function locked when going to Engine or map sections - can get in to ABS & alarm ok.
With the website being primarily for the original nanocom, not exactly helpful 2001 TD5 110 DCPU in Bonatti Grey
Post #52350 11th Jan 2011 12:45pm
Lorryman100
Probably my fault as after rereading my first reply I realise I could have explained it better.
License1 = unlock box No1
License4 = unlock box No4
License7 = unlock box No7
If you have done the above, recheck the codes you have entered into the nanocom as you may have entered a wrong digit somewhere Thumbs Up
Post #52351 11th Jan 2011 12:49pm
daviec1
Sounds like a plan - just as well I saved the pre-entered codes
I'll give it a try this afternoon, and advise
Cheers 2001 TD5 110 DCPU in Bonatti Grey
Post #52353 11th Jan 2011 1:02pm
Lorryman100
Doesn't matter if you saved the pre -entered codes as the unit is looking for the correct code for the module before it can be unlocked. Just enter the license codes into the corresponding box and forget about re entering the pre entered codes in the other boxes as they are locked to you anyway as you have not purchased the unlock code for them. Thumbs Up
Post #52354 11th Jan 2011 1:11pm
Blindpugh
Thanks lorryman I'am in just need to find out where to find the live data revs temp airflow etc. He who dies with the most toys wins.
Post #52356 11th Jan 2011 1:15pm
mse
Got mine
Comprehensive instructions included...but my german is beyond poor (i did learn german once).
I assume its out to the car, get the ID, register it online, get the software download or licence and apply to device? Mike
Post #52360 11th Jan 2011 1:25pm
Lorryman100
It's just that easy Thumbs Up
Post #52362 11th Jan 2011 1:28pm
Lorryman100
I'm off to work in a minute so thought I would post what I did to get my unit up and running.
1. Took unit to car and plugged in, On main screen, pressing the bottom nanocom option gives access to the units ID.
2. On to the nanocom website and registered my units I.D. Tip, Mattia is having server problems so just enter the units ID and your email address.
3. Nanocom email you your login and password details to allow you access to the restricted section. On entering the restricted section you are given access to your units licenses. Note them down and take unit back out to car.
4. Plug unit in and go to nanocom tab and select the licenses tab. Enter the codes carefully following this guide:
The amount of licenses you need to enter depends on the version purchased.
5. Once all the licenses have been entered scroll through all the license pages until the last page and save the changes made. Otherwise you have to start again.
6. Unplug nanocom and then re plug in and voilą your nanocom is ready to go. Thumbs Up
HTH
Post #52364 11th Jan 2011 1:44pm
mse
Aslong as you remember to save it!!
It is that simple...rather worried on the number of faults logged!!!!!!!!!!!...!!!!!!! Mike
Post #52365 11th Jan 2011 2:08pm
Page 1 of 3 123>
