![]() | Home > Puma (Tdci) > puma acceleration problem |
Nice and easy then
![]() But shout it at them in German because life is also terrifying and confusing... |
dulwich man Member Since: 29 Nov 2011 Location: Dulwich Posts: 64 ![]() ![]() ![]() |
10 Amp fuse from memory - could be wrong!
Proven!
It's a 15A fuse (F13 on mine) - pull it out and the engine revs for a while each time you've given it some welly and put the clutch in. Matt ![]() But shout it at them in German because life is also terrifying and confusing... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
too early to say but could a faulty brake light bulb cause similar problems?
replaced fault n/w brake light bulb last night and a short drive this morning had the engine running well? could it just have been coincidence? |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Very interesting!
I have RDX LED's fitted, and have even changed the 3rd high level brake light for an LED one. I have the 'revving' between gear changes issue intermittently, if you put it into low box it happens all the time. It doesn't bother me but strange how it happens intermittently! ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
could be a loose fuse
just to let you know the dodgy bulb that was replaced seemed to make no difference.
1ten.neuss Member Since: 07 Nov 2008 Location: Neuss Posts: 27 ![]() ![]() ![]() |
I had the issue with the blown brake light fuse F13 (10 A) just yesterday when towing a horse trailer. I replace the fuse by a new one and no more increased rev when pressing the clutch.
![]() Regards, Bernd |
Presumably that's the fuse that provides a feed to the clutch switch?
