![]() | Home > Puma (Tdci) > puma acceleration problem |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Nice and easy then
But shout it at them in German because life is also terrifying and confusing... |
| dulwich man Member Since: 29 Nov 2011 Location: Dulwich Posts: 64
10 Amp fuse from memory - could be wrong!
Proven!
It's a 15A fuse (F13 on mine) - pull it out and the engine revs for a while each time you've given it some welly and put the clutch in. Matt But shout it at them in German because life is also terrifying and confusing... |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346
too early to say but could a faulty brake light bulb cause similar problems?
replaced fault n/w brake light bulb last night and a short drive this morning had the engine running well? could it just have been coincidence? |
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282
Very interesting!
I have RDX LED's fitted, and have even changed the 3rd high level brake light for an LED one. I have the 'revving' between gear changes issue intermittently, if you put it into low box it happens all the time. It doesn't bother me but strange how it happens intermittently! Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
could be a loose fuse
just to let you know the dodgy bulb that was replaced seemed to make no difference.
| 1ten.neuss Member Since: 07 Nov 2008 Location: Neuss Posts: 27
I had the issue with the blown brake light fuse F13 (10 A) just yesterday when towing a horse trailer. I replace the fuse by a new one and no more increased rev when pressing the clutch.
Regards, Bernd |
Presumably that's the fuse that provides a feed to the clutch switch?
