![]() | Home > Technical > Who wants a Nanocom Evolution |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Tried that, the little .exe file runs ok but doesn't detect the Nanocom unit via USB, have tried plugging in/out etc but it doesn't see the unit at all. My PC is seeing the Nanocom but this little piece of software isn't for some reason Andy
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Is the nanocom visible as an extra drive in My Computer
Edit:
Is the nanocom visible as an extra drive in My Computer when the upgrade program is running ![]() |
Yes Andy
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
NO! dont do the kernel update...that was my point (i think thats what you were going to do with the .exe) The firmware is just a quick file copy - different I know loads of people who use it on the SLABs system - so im not sure what wrong with yours...just as on the LRO forum Mike |
Sorry for the delay in getting back to you, had to go and get unit from car and check the firmware, files loaded dates and the versions available in the upgrade packs. So for me anyway, my unit is up to date with no updates required. I take it your's is the same Andy? Where about's up north are you? It may be worth trying another nanocom unit in your disco to check to see if it's your unit. software issue or a problem with your disco. Otherwise it's just going to be a case of waiting on Mattia getting back to you or you taking it to a dealers.
I am just thinking aloud here, all unlock codes entered correctly? I take it there are no faults logged within the SLS / ACE / SLABS?. Did you test the SLS functions, all readings values consistent? Does the air suspension test OK on each corner? Can you now disable the Transporter mode now that you are in Coil mode? Does the unit allow you to alter the suspension height and save settings when you are in coil mode or is that option missing? I dont have a D2 in the drive to check myself but these are the type of things I would be trying if I did ![]() |
Every other function change and setting adjusment seems to work fine, it's just this transport mode that is stuck. Andy
"see workshop manual", wonder if we are missing something unrelated to the Nanocom ![]() |
I have the workshop manual and it just descibes what transport mode actually is.
It is certainly what mine is now doing. Andy |
that was my original thought Mike |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
CFB what firmware version is your tool on ?
Pete |
It's on;
Kernel 1.01 Main firmware 1.2 Graphic 1.2 OBD 1.01 Andy |
Thanks, im not sure of the latest but ill try and check.
It is weird that you cant update it though, what operating system are you running on the pc ? If the firmware exe is small eniough can you email it to me please bellautos@hotmail.com Pete |
Whoo hoo, its fixed!!
Bug in software means the parameters are inverted so saving as ENABLED makes it DISABLED Mattia at Nanocom sorted it ![]() |
