![]() | Home > In Car Electronics > Evoque Torch |
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 ![]() ![]() ![]() |
I couldn't do that to my dash
![]() Front of the cubby above the cup holders yes, but not the dash ![]() |
My issue with fitting it in the seatbox is that you have to stop the vehicle, get out, remove seat base, remove cover and find torch. In the dark, I'd need a second torch to do all that.
If it's not reasonably to hand, what's the point? |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Supacat.
You have it wrong, not inside but fitted into the seat box under the clip that holds the top cover down. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
I can�t see any stability problem with cutting a tidy hole into the front of the seat box. Had considered doing similar in the side of the seat box. The torch wouldn�t be accessable when on the move but easily reached when climbing out. Nicely presented when opening the door. It isn�t a map reading lamp anyway. Er no, I haven�t fitted it yet, either. On the list..... ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT�s, Recaro CS�s, anorak, wellingtons |
Al_The_Pal Member Since: 09 Feb 2015 Location: Near the bottom on the right Posts: 146 ![]() ![]() |
I'm not keep on cutting the dash either, so have decided to fit one in the top of the passenger side "glove box" panel, I've bought a new genuine spare for 22 quid, can cut that about at leisure, make a tidy job and simply swap the panel out.
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2660 ![]() ![]() |
i did see the other day someone who has installed this into the side of a cubby box.. looked really nice and tidy.
i couldn't bring myself to cut such a big hole in the dash ![]() i just keep a full side mag light down the side of my seat between it and the cubby... wedges nicely |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 411 ![]() ![]() ![]() |
I have to say, once fitted, it looks like it came standard from the factory. Specially as the torch is LR branded.
You lot need to man up, I have another two holes in the other side now..... ![]() Click image to enlarge |
The problem I see with installing it on the side of the cubby box is that you will lose half the storage inside. The cradle is quite deep and there is a load of electrical gubbins on the back as well.
The seat base is quite a good idea, what about the soundproof matting? It might be to thick for the standard mounting method of the cradle. I will be interested to see what people decide. I wonder if I will regret cutting my dash to bits ![]() ![]() |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
Not a great pic but heres mine built into dash:
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
Bristol, that looks pretty factory fit - very nice!
![]() I also like where Andy (MCMA1) put it in his Corris 110 http://www.defender2.net/forum/topic40056-75.html - about half way down I honestly cant decide which I prefer! |
http://www.defender2.net/forum/topic42703.html
If anyone is interested in getting one of these - group buy |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 264 ![]() ![]() ![]() |
Hi
If anybody else is interested I have one that I would sell, bought from Dan but not fitted and have had a change of plan. Sorry Dan Would like to get my money back but will take �85 posted. |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
I will take the torch off you... Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Williamraff Member Since: 19 Mar 2017 Location: Leeds Posts: 40 ![]() ![]() ![]() |
Hi folks,
Have I missed the boat on this one? I would love one - rechargeable torch in a Land Rover - great idea ![]() If someone could let me know it would be greatly appreciated. Thanks, Will. |
