Home > My Defender > Corris 110....
Page 6 of 48 <123 ... 567 ... 464748>
mcma1
Recycled the old cubby lid to make an enclosure around the switch cables. Still plenty of space to store the usual cubby crap.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #467046 27th Oct 2015 6:15pm
mcma1
Winch installed.
Had new cables made up by mobilecentre to avoid any connections. All working well, getting the rope through the spool was a right PITA... Took a lot of lube...
2014 Corris 110 SW
LS3 V8 build...
Post #468091 31st Oct 2015 2:35pm
mcma1
Completed the front lighting with a Lazer ST-8, it lets me keep the TS4000 aiming further ahead and this with the headlights. Made up a few brackets to hold it onto the A bar fixings.
Anyone using one of these on he rear?? Badly need to get some extra light out there.
2014 Corris 110 SW
LS3 V8 build...
Post #471334 10th Nov 2015 5:14pm
JOW240725
While you're at it you might was well put one each side on the rack as puddle lights! Laughing Shocked
Post #471339 10th Nov 2015 5:35pm
mcma1
Well as Xmas is around the corner fairy lights on the rack would be a better bet. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #471347 10th Nov 2015 6:02pm
JOW240725
Now you're just being silly!! Go on then dare you!! Thumbs Up
Post #471350 10th Nov 2015 6:13pm
mcma1
Evening shot with the birds making a lot of noise overhead... Shocked
2014 Corris 110 SW
LS3 V8 build...
Post #471686 11th Nov 2015 7:27pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I always loved your 90 but this is awesome. Its great to see top quality workmanship too Thumbs Up
Post #489318 6th Jan 2016 8:29pm
mcma1
Thanks buddy, loved the 90 myself and even tried to buy it back!!! This is turning into a dream spec defender for me, and I just love working at it myself, trying different ideas. You have already seen my torch install over in group buys but just going to add the pictures in here....
Used the kit template and jigsaw..
Easy enough install, made up a few brackets which just make it rock solid as you do need to give it a bit of a pull to remove it from the base.
Ordered the classic mantec RAI today, then plan to install the twisted progressive suspension setup. Thought I had finished my list of mods !
2014 Corris 110 SW
LS3 V8 build...
Post #489354 6th Jan 2016 10:30pm
JOW240725
Torch looks great in that location! Not as in your face as on the dash.
Post #489361 6th Jan 2016 10:37pm
mk1collector
I was thinking of the cubby when I saw the torch group buy but thought it might intrude too much inside. Any pics inside to see how much room is left?
Looks great btw Thumbs Up
Ray Ray
My build thread
Post #489367 6th Jan 2016 10:43pm
mcma1
Taking the thickness of the cubby mdf and vinyl I reckon it sits about 50mm inside.... I didn't mind as I already used this side for my switches but I still have my bottle Jack, winch remote and cable, gloves, and few other bits and pieces stored in there!
The dash installation is too obvious as you say, the front of the seat box would work well too. Smile but I kinda like it being visible. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #489374 6th Jan 2016 10:52pm
Morepower
New Zealand
Great Build... where did you put the puddle lights in the end?
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #489441 7th Jan 2016 1:36am
mcma1
Thanks Tim,
I did add the lights into the front footwells, into the underside of the dash as this was a good place to get a good secure fit.. Just a 35mm hole needed then dremel'd out for a good fit. Wired into the interior lights so they come on with the remote and then also wired to come on with the side/headlights etc. Hard to get pictures but even off centre they light up the footwell really well, nice and subtle. I do plan to change all the interior bulbs to LED which should help even more.
2014 Corris 110 SW
LS3 V8 build...
Post #489613 7th Jan 2016 4:13pm
Morepower
New Zealand
That looks really factory... Do you have the part numbers for the lights and connectors etc etc?... I fancy doing this to my 110 also..
Post #489615 7th Jan 2016 4:21pm
