![]() | Home > My Defender > My Defender rebuild |
| steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076
Your such a tease
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Looking good so far, can't wait to see its next reincarnation
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2530
Try selecting just one pic and make sure its a low ish res or not too big a size?
sorry for the non techy reply 2015 Discovery 4.5 Black pack Firenze red XS |
| steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767
Good postings, looking forward to the rest
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596
I dropped in a 4HP22 gearbox from Ashcrofts. Very easy when working on a rolling chassis!
Click image to enlarge |
| smbaker Member Since: 29 Jan 2014 Location: Essex Posts: 5
Does the V8 box mate to the 300 backplate without modification? Presumably need new flywheel torque converter etc ?
Looks a v nice build |
Its a 300tdi box so straight on, but you do need to swap the flywheel for a flexplate and its a different flywheel housing too. Nothing too difficult though.
Next I turned my attention to the rear tub. When I rebuilt it onto the new chassis I didn't do any bodywork, it was just a lift off lift on job. This time I wanted to do a more thorough job and the rear tub was looking a little worse for wear.
The under tub strengtheners were all completely shot. I ordered a complete new set of aluminium top hats (the pieces that run front to back) and new galvanised cross braces from YRM Metal. Click image to enlarge |
New top hats riveted on ( the originals were spot welded).
And then the cross braces.....
Next I stripped the tub of all its old paint. I wasn't happy with the old paint and so I went down to bare ally to start from scratch.
Stripped it off with industrial paint stripper. Brushed it on and then jet washed it off leaving clean ally. Click image to enlarge |
Then sprayed it up with my chosen colour I had custom mixed. It is a lovely dark grey with a satin finish.
This was the first body panel to be sprayed so it was a bit of a scary moment to see if the colour and finish would be as I hoped for. Click image to enlarge |
Next I sprayed up the bulkhead. This is not the original bulkhead, but a brand new TDCi bulkhead that I had modified and then hot dipped galvanised.
So now I don't have vent flaps anymore. I never used them and it is once less place to leak and I can now sound proof and insulate better. Click image to enlarge |
| All times are GMT |
